06-26-2003, 01:12 PM
2 Slow and 2 Curious
thanks for all the kind comments you guys!
::loving the attention::
06-26-2003, 01:26 PM
0reZepyT
yeh glow is beautiful, it's nice adn pretty even all around. only wished teh radioshacks in my area didn't stop stocking the blue led's....hell they even took it off their website....stupid rat shack. the only other electronics store that woudl sell bright blue led's is like a 30 minute drive from here cuz the yellow pages website wont decipher for me whihc business is a store and wish is a warehouse distributor
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
06-26-2003, 02:47 PM
if you ever order the laymans cells from all electronics, then get some leds from there while you're at it.
06-26-2003, 06:42 PM
wut kind of led wus that? just wondering...im asking u about everything now lol  hope u dont mind
i was figuring that since im picking up those batts (with $6 dollars shipping i mite add  ) i decided to pick 1 up
heh, im not too good at these things  lol
I've got a good car in the works  ill post pics here when im finished  its a German 911 black porsche  im hoping to get it to wheelie with all this torque and weight im adding to the back...anyway the result shud be really nice
"I am very very sneaky sir"
06-26-2003, 06:54 PM
not so bright
ME WANT LIGHTS!!!
06-26-2003, 07:12 PM
ill feel stupid now...  im realising that my cars gonna look alot like urs and ur not replying bcuz of that (i think)
06-26-2003, 08:06 PM
lol, im flattered that i inspired you
(you know i DO have a life outside of micros you know  )
actually i was out running around because the bank screwed something up and that needed fixed. and i had to go to walmart. and mcdonalds  for ONCE they didnt screw up my order so this is a good day
as for the LED, it is a blue(obviously) 2600mcd, 3.7v typical, 4.5v max, 20mA, 5mm LED. if you do it the same way as i did, you may have a hard time fitting the porsche on the chassis. try the pt if this is your first time, it is a nice car, purple and that teal greenish that they came in look great with a blue under glow. i used a CR2032 lithium battery. if you want to fit smaller bodies on there and more easily, then get a smaller battery. anything that is 3v will do good.
06-26-2003, 08:15 PM
u can turn the lite off rite? sorry im not to great at this electrical stuff as u can c...  lol if u cant turn them off r they recharcable? if they r u must have to hook them up to the otha batts...
06-26-2003, 08:44 PM
no they arent rechargable, but lithium batteries last a long time and the current drain on these leds is really low(20mA). meaning if it was running on a tomy 200mah battery for example, i would last about 10 hours non stop. you turn them off by disconnecting the battery. you CAN attach it to the regular battery by just fitting the led arms on each ends of the battery, but it would just drain that faster and with the LED i used, its typical required voltage is 3.7, so im already pushing it with only 3v, in a stock car it only uses a 1.2v. my car has 3.6v but it would cut my runtime in half because it drains at 20ma, my batteries are 40mahs so i would see much shorter runtimes.
06-26-2003, 08:55 PM
do u hav to solder it? if u do, how r u supposed to disconnect it?
06-26-2003, 08:59 PM
you dont solder it to the batteries. i just use wire and tape the wires in place. i find that putting some aluminum foil ont he end of the wire and wrapping the wire up in that and then flattening it witha set of vise grips will get a better connection because it isnt as easy to break loose.
06-26-2003, 09:02 PM
i wonder if i cud fit 2 leds in there...i doubt it...u wud kno, cud i?
the minimum u can buy on www.allelectronics.com is 10, so i need to do sumthin wit dem...
o yeah is there anythin else i can get on www.allelectronics.com?
1 NMH BATTERY PACK, 7.2V 40MAH
10 MINI GREEN LEDs
1 LITHIUM BACK-UP BATTERY, 3.5V 1AH
06-26-2003, 09:24 PM
where r u now flatlander, at wendys?
06-27-2003, 01:03 PM
no, work....
and just got back from burger king
you could try and fit 2 leds in there, but its not necessary. green will be much brighter than blue because blue and white are the 2 most voltage sucking colors there are. green will be mad bright as it is with only one. hold on to them and use them as back up... other wise send the extras to 1205 madras ct......  and get more than one nimh pack. order 4 to be safe. i ordered 4 and im almost done with them. you should replace the batteries every 3 monts or so because they lose their punch.
