Old 06-21-2003, 07:29 PM
SSRay SSRay is offline
2 speed
Do two speed cars go half of their full speed...then when you press the button it goes full speed?
Old 06-21-2003, 07:31 PM
I have a beach ball...
That's the way my pro works. It's not any faster than say a sport, but it goes slower off the boost.
Old 06-21-2003, 08:10 PM
oh ok...i have a regular microsizer..just wondering how the 2 speed works. thanks
Old 06-23-2003, 11:00 PM
Char-g Ace's Avatar
Char-g Ace Char-g Ace is offline
I need to change my Title
My 2 speed goes a lot faster than my sport. but that might have somthing to do with the dual cell. LOL
4 Bit Char-g Failiers
1 Microsizer
3.8 motor
Duel Cell sucess
Celica body
Old 06-24-2003, 01:00 AM
2G2SILVERSTRAT 2G2SILVERSTRAT is offline
im rick james bytch
Send a message via AIM to 2G2SILVERSTRAT
mine stays even with my girls sport then with the boost button "bye bye:" its hauls a55
Old 06-24-2003, 11:44 AM
MicroSpeed's Avatar
My PRO only goes 1/2 speed without boost but with it is much faster. Then again, the only comparison was with my friends standard MS, which he got last year, so it problably not up to spec anyway. If you are wondering which one to buy, get the PRO anyway, because it helps alot for tech-tracks. unboosted for tight turns, boosted for acceleration and top end on straits.
David
Old 06-24-2003, 11:49 AM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
pros get horrible range
Old 06-24-2003, 11:50 AM
MicroSpeed's Avatar
oh and one other thing. A MS PRO has a 2.2 moter and a Sport has a 1.6
Hopefully that will help you with comparisons.
in other words, the PRO has a motor that when in boosted mode is at least 1-3/8 faster than a sport
Old 06-24-2003, 11:55 AM
MicroSpeed's Avatar
I agree, the antenna an PRO's is quite a bit shorter than on standards. what i did is i went under the pcb board, untied the knot in the antenna and drilled a hole in the front of the body for it to come out, which made the antenna about 1.5 inches longer, and improved range by 5-10 feet
Old 06-24-2003, 01:04 PM
im rick james bytch
UNTYING THE KNOT WILL GIVE IT MORE RANGE i got an extra 5 feet........and for spme reason the 49mhz pro has better range the the 27mhz pro....go figure
Old 06-24-2003, 02:05 PM
MicroSpeed's Avatar
good thing ive got the 49
Old 06-24-2003, 02:36 PM
hogjowlz's Avatar
thats bs. pros(at least the two i got) have very crappy range even after trying a few different types of wire and boosting the signal on the tx. the only way to substancially increase range on a microsizer is to change the pcb.
Old 06-25-2003, 12:03 AM
im rick james bytch
your b.s. is pure b.s. ive had about 5 microsizers 3 were 27mhz and 2 were 49's .the 49's are clearly higher quality then the 27's and untying the knot does add about 5 feet max range.... on the 49's ..it only adds 1-2 feet on the 27's/ sorry but facts are facts.regardless how many post you have.....
Old 06-25-2003, 03:50 PM
hogjowlz's Avatar
well maybe you got special "magical bits" but i doubt it.
Old 06-25-2003, 04:54 PM
im rick james bytch
i just bought another 49mhz pro to test my theory .and i was correct again about only 4 addition feet this time after untying th knot.....my bad if you think im being an A55 im not trying to be just sharing my experiences.. cool?
SE 1/4 mile speed tests Steve ZipZaps SE 8 02-08-2006 03:04 PM
The Infinite Speed Potentiometer Mod (tm) actofgod Bit Science 46 09-16-2003 05:47 PM
speed speed speed ml22 Bit Char-G / MicroSizers 6 03-14-2003 01:27 AM
modified a body to fit Speed Racer Spec 1!! nojodash Epoch RC1/43 0 01-18-2003 10:16 AM
2.2 2 speed vs 2.6 1 speed eman1 Bit Char-G / MicroSizers 0 12-16-2002 09:34 PM
