Old 06-23-2003, 10:42 AM
esp rocker's Avatar
esp rocker esp rocker is offline
Send a message via AIM to esp rocker
running lights from car battery
I am adding lights to my microsizer today or tomorrow, and I need to know how easy it would be to run the lights using the stock battery, which is 120 mAH I believe. What exactly would I need to do to run lights with the car battery, and how many could I use with that as the power source? Also, what kind of LED's should I use? Please be specific, because I really have no idea what kind of lights I need. Thanks a lot
Old 06-23-2003, 12:06 PM
Smurf Smurf is offline
Lube Master
Send a message via AIM to Smurf
the stock battery is 50mah and it would REALLY suck your batterys up if you had more then just 1 or 2 very small 3mm leds
http://www.halffull.net/phast.jpg
Phear my phast motor icon!
Old 06-23-2003, 12:47 PM
teamoutburst's Avatar
teamoutburst teamoutburst is offline
TINY RC RULEZ!
you could use a boost convertor to get an added boost in voltage to run your lights
My Car:
Old 06-23-2003, 01:05 PM
esp rocker's Avatar
hmm what exactly is a boost converter? where can I find one? thanks a lot man
Old 06-24-2003, 02:23 AM
TINY RC RULEZ!
A boost convertor is a regulator that takes an input voltage and boosts it to a bigger voltage, there is some info at http://tinyrc.com/forums/showthread....threadid=11489
My Car:
Lithium Ion Battery Mod 300+ MAH LBRC Micro-T Parts and Hop-Ups 19 04-21-2007 11:39 PM
must have upgrades worth every damn cent times 10 teklife Bit Char-G / MicroSizers 4 12-06-2003 07:44 PM
can i use this battery on my car jaws Bit Char-G / MicroSizers 1 11-21-2002 12:32 PM
In Car Crip Cap Questions poopeebum Bit Char-G / MicroSizers 0 11-19-2002 12:21 AM
Dual Batt. Mod stevensmd3 ZipZaps 13 11-16-2002 04:03 PM
