Old 06-05-2003, 09:31 PM
killer's Avatar
killer killer is offline
Proud to be Pinoy :)
Talking my 1/32 version of Tamiya Bruiser..
hope you like it!
hehehe
Old 06-05-2003, 09:32 PM
killer's Avatar
front view
hehehe
Old 06-05-2003, 09:35 PM
killer's Avatar
with 1/32 Tamiya Toyota Land Cruiser Paris Dakar Rally body on..
hehehe
Old 06-05-2003, 09:36 PM
killer's Avatar
ArTiCuLaTiOn!!!!
hehehe
Old 06-05-2003, 09:37 PM
Maxxcrazy Maxxcrazy is offline
skylinepimpinR34-Bit Pimp
Send a message via AIM to Maxxcrazy
Where do you buy those axles? Or do you make them?
Skyline Microsizer
Thunder Charger Clone
Old 06-05-2003, 09:38 PM
killer's Avatar
size..
on top of my hand...
hehehe
Old 06-05-2003, 09:40 PM
killer's Avatar
:ö: yes, those are hand-made axles..
hehehe
Old 06-07-2003, 06:43 PM
micro kid's Avatar
Do you getto dremel?
there's only one thing i can say,
schweeeeeeettt!!!!!!!!!!!!!!!!!
Old 06-14-2003, 11:34 PM
r.c.dealer's Avatar
r.c.dealer r.c.dealer is offline
deviant bit char-g pro
If you can find an old Tamiya 1/32 battery powered Sand Scorcher 4wd kit that would be cool, as one of the bodies just happened to be an old Toyota Hilux body just like the full size rc 4x4 hilux, bruiser, and mountaineer.
My Castrol Supra booster bit owns you!!
Old 06-14-2003, 11:39 PM
r.c.dealer's Avatar
By the way that chassis is to cool for school!!!
What kind of joints are you using up front to allow the front wheels to turn, as I noticed it is 4wd. Also what kind of gears are you using for the axles and the transmission? What about the steering blocks up front. I might have to make my own
Old 06-15-2003, 05:29 AM
killer's Avatar
:ö:
thanks r.c.dealer, the u-joints used on the front wheels to turn are handmade by me, out of a 4mm steel shaft (check out some of the pics of the u-joints i made at my gallery on TTTT thread i also have made some u-joint out of 3mm steel shaft to make my 6x6 1/87 truck all-wheel-drive! i got some video there too to prove it's all-wheel-driven capabilities and the strength of those steel u-joints) the gears set used for the tranny came from Tamiya Racing Mini-4WD with 5:1 gear ratio, and the gears at the axles are combination of a worm and gearset, so i expect this truck much faster than the other trucks i made, now that steering block, i curve that thing out of a thick brass tube.
yes, this truck is going to be like it's bigger version, i've already made a waterproof electronic box, so submerging the truck on a headlight high water will be possible
hehehe
Old 06-17-2003, 10:15 PM
killer's Avatar
Talking 1/32 bruiser in color
hope you like it!
hehehe
Old 06-17-2003, 10:21 PM
killer's Avatar
sideview..
hehehe
Old 06-17-2003, 10:24 PM
killer's Avatar
size..
hehehe
Old 06-17-2003, 10:34 PM
killer's Avatar
rock crawling tires...
:ö: modified Tamiya Monster Tires for Rock Crawling..
hehehe
Tamiya Tamtechs fastmax Tamiya M-Chassis 5 10-29-2007 12:39 PM
FS NIB TL-01 Tamiya XB FORD F150 Lightning 4wd RTR Set kylelucas For Sale/Trade 2 10-28-2004 06:39 AM
can someone find the full version of this video? 323iT Bit Char-G Gallery 3 11-04-2002 01:16 PM
Tamiya Championship Series slotsurfer Tamiya M-Chassis 5 09-28-2002 09:02 PM
