Old 06-15-2003, 11:50 AM
SupraMan017 SupraMan017 is offline
Type-R
Send a message via AIM to SupraMan017
Range Poblem
I have the X-Men rx8 with a dual cell mod. It was working fine for awhile but now unless thhe contoller antttenna touchhes the pcb of the car itt does nothing. Can anyone help me?
My XMOD:
Acura Integra Type-R
180 Motor with Drag Pinion
6-Cell Upgrade
FWD
Locked LSD
Hard Springs Front and Back
Soft Slicks in Front
Hard Slicks in Back
Old 06-15-2003, 12:03 PM
Azimov's Avatar
Azimov Azimov is offline
I process, therefore I am
Well, if the car works when you touch the antenna to it then everything is working except the signal. This means you have an antenna connection problem. Check the solder point of the antenna inside the car to see if it came loose when you did the mod. Check the one in the contrioller too if you've been pokin around in there as well. Also, make sure you have new batteries in the controller.
ZZMT Remote Range 88-Fiero-GT ZipZaps Mods and Projects 1 10-09-2005 09:03 PM
Poor range kennylxix XMODS 7 12-22-2004 02:13 PM
Question about range 05WillysJeep ZipZaps Monster Truck 2 12-11-2004 04:43 PM
range of 27 MHz versus 49 MHz gRC ZipZaps 12 09-30-2002 06:33 PM
