Old 05-28-2003, 07:11 AM
malform's Avatar
malform malform is offline
representing Deutschland
Send a message via ICQ to malform Send a message via AIM to malform
I did a quad mod last night, I used the truck that has the bigger body so it all fits under there. I must say tho, I'm not as pleased with the resaults as I thought I would be. If there is any noticeable difference in speed it is very minimal. I can say however the run time is much longer, I got tired of playing with it before it was dead.
Should I have seen more increase in speed and power? Maybe I did something wrong?
Old 05-28-2003, 08:21 AM
Buzzbait's Avatar
Buzzbait Buzzbait is offline
The quad-cell should be much more powerful than the stock dual-cell. It should be a little hard to control with 4 cells, and have a slight tendency to flip onto its back when starting forward.
If you went from 2 cells to 4 cells, and only notice an increased run time, you may have accidentally hooked up the batteries in parallel instead of series. Parallel will give you extended run times (current). Series will give you more power (voltage). Here’s a diagram of how the batteries should be connected, if you are running both extra cells from the battery in the back of the truck.
Old 05-28-2003, 12:07 PM
malform's Avatar
Rock!
I went home at lunch to re-wire it.. I did have them in parallel. Now its awsome, much more fun than out of the box.
Thanks buzzbait.
Old 05-28-2003, 03:52 PM
Lord_Nick_D's Avatar
I cant stop modding
also the more you charge it the better
I had to charge mine like 4 times to get the full power out of the batteries
and it didnt last too long
I added another 2 cells to the normal charger for a 3 cell car so is 6 cells chargeing a 3 cell car ok
Old 05-28-2003, 04:58 PM
rt450 rt450 is offline
guitars, cars and fishin'
i use a 9v battery for 2min. to charge my 3 cell.
don't lose your password
Old 05-28-2003, 10:14 PM
Buzzbait's Avatar
All of my modded cars go o a Piranha digital peak charger. The best $50.00 I ever spent.
Old 05-29-2003, 06:31 AM
malform's Avatar
I was charging the quad I did with my super brain... But last night I wired both of the chargers I had together.
First I only wired it so it used 2 batteries out of the second charger. Then I ran the trucks batteries all the way down (took about 40 mins btw) and used my newly wired 6 cell charger to charge it just for a test. It maxed the truck out at about 5.2 volts. So just to make sure it does the job right each time, I re-wired it to be an 8 cell charger... Still need ot test the 8 cell charger.
Old 05-29-2003, 06:20 PM
I cant stop modding
8 cells is way too much your charging it with double the voltage
Old 06-13-2003, 01:30 PM
takumi_drifto's Avatar
takumi_drifto takumi_drifto is offline
DriFt OnLi
Send a message via AIM to takumi_drifto Send a message via Yahoo to takumi_drifto
Man , i want some of those!!
so ur saying they come with extra bodies u can buy? or you just bought more Sets?
DriFT_
Old 07-14-2003, 02:31 PM
buzzkill buzzkill is offline
Send a message via AIM to buzzkill Send a message via Yahoo to buzzkill
4*4 mod
has anyone tried to remove the gears and motor from the front wheels, to convert it to 2 wheel drive? is it possible?
Old 07-14-2003, 03:11 PM
malform's Avatar
They steer like a tank, so you need the 4wd to turn :|
I have now idea why you would want to remove 4wd from something that’s already 4wd… That’s not an upgrade, it’s a downgrade :\
Old 07-14-2003, 03:55 PM
2 wheel drive
making a 2 wheel drive truck may speed it up a bit, it will also get rid of excess weight. and if you run the dual motor to the back you can still steer, (like a digi q)
Old 07-14-2003, 05:49 PM
I cant stop modding
yeah but turning isnt as good because these are not porpotional speed
steering with 4 wheel drive is easier
Just put a 3rd cell in it will be fast enough
Old 08-18-2003, 04:38 PM
squeegee's Avatar
squeegee squeegee is offline
Tiny RC Expert
I know this thread is really old but....................I tried wiring my truck up with 2 extra button cells on back...........its wired perfectly fine. I think it's in my charger.........all I did was cut the plug off of the stock charger and rewired onto a 9 volt battry holder.............................What am I doing wrong, it doesnt work at all.
Old 08-19-2003, 06:18 PM
I cant stop modding
the 9 volt probably isnt supplying enough current to charge your batteries What I did was get a plug in wall transformer at the same voltage as the normal charger and use that to charge my tri cell truck
it works great
you should also charge it a couple of times
you also could have fried the batteries
super slicks monster truck 4x4 whatsupdoc79 SuperSlicks Gallery 6 02-18-2006 06:12 PM
Pics of my ZipZaps Monster Patrol Monster Truck -:) rfnagel ZipZaps Monster Truck 20 11-19-2004 07:13 PM
How big are the micro machines monster truck tires? Ovgron Bit Char-G Parts and Hop-Ups 0 06-18-2003 03:09 PM
QFM Monster Truck Mod Pics QFM Racing Bit Char-G / MicroSizers 2 08-22-2002 12:56 AM
