Go Back   TinyRC.com > 1/64 and Smaller > Digi Q > Combat Digi Q
Old 06-12-2003, 07:41 PM
zot zot is offline
Send a message via AIM to zot
A question of battery life...
I noticed just my panther no longer has the same battery life (in the tank) than my friend's, even with new batteries in the controller.
So here's a few questions...
Do the rechargeable batteries gain a "memory" over repeated uses? If so, is there a way to get rid of it? If not, the batteries will eventually become useless due to a short period in which they remain charged, would there be an easy way to replace them? What kind of batteries are they and where would I get them?
Sean
Old 06-13-2003, 11:54 AM
Napalm_Guru's Avatar
Napalm_Guru Napalm_Guru is offline
Wanna Drag??
check if you're using nickel cadmium batteries, because you shouldn't. Also make sure they're all the same brand, and type.
If you already tried this and you have a first generation tank, you may need to remove one battery from the controller after use. This cuts the power to the controller and will stop the battery draining problem, that some people with earlyer tanks have.
hope this helps.
"Going to war without France is like going deer hunting without an accordion. You just leave a lot of useless noisy baggage behind.
-Jed Babbin
Old 06-13-2003, 12:19 PM
Alard Alard is offline
I've experienced . . .
a similar problem with a Digi Q Panther. From what I've heard, the NiMh batteries are not as reliable as NiCad batteries. Whatever, my Panther needs a new battery pack allready.
It runs out of juice in about two minutes.
By the way, this is when charging using the 4 position stand-alone charger. It works great with my other tanks.
So far, been unable to locate these batteries in small quantities.
Probably will buy a bunch and sell them to others who have the same problem.
http://www.maid.gr.jp/products/c-dig...oyshou-002.jpg
Old 06-13-2003, 12:54 PM
zot zot is offline
Where have you found them, in what quanities and how much?
I was considering geting a few and seeing if I could make them removable from my tanks. Just need to add a plug of sorts onto the wires so I can remove them.
Old 06-13-2003, 01:17 PM
individual cells would be
about $2 each + shipping.
Installing a connector sounds like a good idea.
Old 06-13-2003, 01:22 PM
zot zot is offline
$2 each? that's not bad at all. Having the connector means you can yank out a crappy battery when every you want or swap in a fresh one if you don't want to wait forever to recharge. (Yet another reason to get the 4 tank charger thing.)
Old 06-13-2003, 04:02 PM
zot zot is offline
What are the batteries called? What size are they?
Old 06-14-2003, 07:52 AM
Digi Q tank batteries . . .
are two cells, 1/4 AAA, 80mAH, NiMh.
This supplies ~ 2.4 volts.
Old 06-14-2003, 09:31 AM
microracer1 microracer1 is offline
Is this the battery recommended by Konami? Exactly the same batteries as the ones from the original tank?
I checked out the site that you posted and found a speaker system, is that for sound effects? Too bad I can't read Japanese! Anyway, it's out of the topic for this forum but I just thought if it's really for the combat DigiQ ... COOL!
Old 06-16-2003, 04:11 PM
zot zot is offline
Thanks for the info. Any suggestions where I might find some online and some small mini-connector plucg I could install?
Increase short battery life! underglow ZipZaps SE 1 09-17-2005 06:51 PM
Quickly diminishing battery life? desmo SuperSlicks 3 06-28-2004 05:25 PM
Simple Tinted Window MOD and how to increase battery life. BigC Atomic Z-Cars 1 06-19-2003 05:26 PM
new to Bit Char-G's...newbie question about battery life chikai Bit Char-G / MicroSizers 4 12-01-2002 10:15 PM
