06-09-2003, 12:09 PM
Type-R
Lowering The Eclipse
Can a the fast and the furious lime green eclipse be lowered? If so how?
My XMOD:
Acura Integra Type-R
180 Motor with Drag Pinion
6-Cell Upgrade
FWD
Locked LSD
Hard Springs Front and Back
Soft Slicks in Front
Hard Slicks in Back
06-09-2003, 01:21 PM
Tortured Primate
The lime green mitzubishi is a lancer evolution. it can be lowered. you need to cut new tab holes in the body and deepen the wheelwells.
i lowered the eclipse spyder convertable.
http://tinyrc.com/forums/showthread....threadid=11010
pics show the slots cut.
Imagination is more important than knowledge...
Albert Einstein
06-09-2003, 01:25 PM
Type-R
no dude its an eclipse from the first fast and the furious
My XMOD:
6-Cell Upgrade
FWD
Locked LSD
Hard Slicks in Back
06-09-2003, 02:12 PM
Tortured Primate
ok...misunderstood you...the answer to the rest of your question is the same....
Albert Einstein
06-09-2003, 02:14 PM
Tortured Primate
you can also replace the tabs on the chassis....you will have to search for that post tho...don't have the link at the moment. but using one of these methods you can lower it.
Albert Einstein
06-09-2003, 02:18 PM
Type-R
aight thanks man
My XMOD:
6-Cell Upgrade
FWD
Locked LSD
Hard Slicks in Back
06-09-2003, 02:21 PM
Type-R
which way is betttter thoughh?
My XMOD:
6-Cell Upgrade
FWD
Locked LSD
Hard Slicks in Back
06-09-2003, 06:01 PM
This Eclipse is tab lowered, and I didn't have to shave the fenders either. I like tab lowering better because you can use it on multiple cars and some bodies don't have the room to cut another slot in.
06-09-2003, 08:14 PM
That's all folks
Yep, I lowered the tabs on my eclipse too. I also put small wheels from microsizer fronts all around, for the real "low down".
That's all folks!
06-10-2003, 07:49 AM
Tortured Primate
front end looks pretty close....you have any clearance problems when you turn? thats why i had to shave back the wells on my spyder.
Albert Einstein
06-10-2003, 05:59 PM
It does look close, but the only time I get any kind of rubbing is if the chassis moves to one side or the other. (My tabs are not exactly the width of the slots in the body. Other than that, it's all good.
