Go Back   TinyRC.com > 1/64 and Smaller > Bit Char-G, MicroSizers, Z-Cars, Clones > Bit Science
Old 06-04-2003, 05:51 PM
Azimov's Avatar
Azimov Azimov is offline
I process, therefore I am
Here's the underside of the body for all you body modders wondering how it attaches to the chassis.
Old 06-05-2003, 06:53 AM
strider_mt2k
Thumbs up
Just fantastic.
Form meets function in the sexiest way possible.
Old 06-05-2003, 09:26 AM
Namuna's Avatar
Namuna Namuna is offline
Wait, now I'm getting a better picture...When you say 50mA, you're talking about capacity and not max mA output, that changes things.
I would then recommend the Tomy 2.6 motor.
I haven't tested any motors with multiple cells (yet) but at the single cell mark the 2.6 is VERY efficient as far as power usage goes (getting nearly DOUBLE the runtime of the 2.2), and pumping the 4v to it will make it a hellova lot faster but maybe still within controllable range.
Old 06-05-2003, 05:20 PM
Azimov's Avatar
I just did some testing of Solar Micro 2 in full brite sun and was a bit disapointed. The solar cell mA ratings are not high enough to run the Motor Works hardware. After the cap charges, the car will literally fly. In fact, it is way to fast. After only a foot or so of forward acceleration combined with a turn in either direction the car would tend to roll several times. Also, the MW motor sucks way to much current and the car would quickly deplete the capacitor. So, I replaced the MW motor with a ZZ blue control motor. This helped quite a bit and I'm sure more efficient motors would help even more. But, there is an insumountable problem concerning using this solar cell. 50-60mA is just not enough current even at these high voltage levels. The problem is that even with a very efficient motor, the steering still pulls a lot of juice. In real driving situations, the motor and steering pull power from the cap that the solar cell can't replace fast enough. This eventually runs the cap dry and you have to let the car sit for a bit to recharge. There is just no comparison with the Solar Zip that I posted earlier. The Zip will run continuously at full speed and turn without a loss of power in full sun and it doesn't have a buffer cap. This tells me that 200mA is the absolute minimum current at higher voltage levels. 100mA would work, but for a car that performs as if it had a stock battery with unlimited run time, 200mA is the minimum. My earlier testing shows that if the voltage is below 3VDC then 300mA is the minimum current. So, it's back to the drawing board for Solar Micro #3! BTW, my tests show that the car that I found on the web which uses this solar cell with a cap and a stock bit clone chassis would not run continuously in brite sun. It would charge, run off the cap, stop and recharge. Solar Micro 2 performs better than this, but is still not what I was shooting for.
Old 06-06-2003, 01:47 AM
alfreema alfreema is offline
Voltage too hot?
It sounds to me like the aerogel cap voltage on your MotorWorks car is too hot. Does the motor generally run at ~1.2 volts like the other micros? If so, that would explain the quick drain of the cap. Maybe use a DC/DC voltage converter to step the cap down to 1.2 volts? Something like Digikey part: NJM2360D-ND
Just a thought.
Old 06-06-2003, 03:39 PM
Azimov's Avatar
I think I see what you arte saying. To much pressure (VDC) is pumping the little bit of current out of the cap to fast. I have my doubts that lowering this will help as the low mA rating of the solar cell would seem to be the culprit. The blue control motor pulls over 50mA stalled. This combined with the steering coils power needs is more than the solar cell can output, putting the circuit in a sort of negative equity situation. I'm not familiar with the part you mention. Does this DigiKey part convert excess voltage into current, or is it thrown out as heat as in other voltage restricting devices?
Old 06-06-2003, 10:51 PM
Azimov's Avatar
Thanks for the tip! I looked the part up at Digikey and printed out the spec sheets. Looks promising. I'll order a couple and see if I can wire up a simple step down converter. This might just work.
Old 06-07-2003, 06:58 PM
No prob, hope it helps. If not in this project it would seem to certainly come in handy down the line with your other mods. I haven't used one, so let me know how it works out for ya.
Thin Film Solar Cells, inspired by azimov Jazz32 Miscellaneous Discussion 5 07-23-2006 01:15 AM
Solar Power theone&only.... Epoch RC1/43 7 12-12-2004 11:51 PM
Solar Micro #3 Azimov Bit Science 29 01-20-2004 01:20 AM
rtr hpi micro rs4. spy esc, 2 bodies, plus extras isk8blind For Sale/Trade 0 08-31-2003 05:38 PM
Solar Zip Azimov Bit Science 21 06-03-2003 02:15 AM
