Go Back   TinyRC.com > 1/64 and Smaller > Table Top Truck Trials (TTTT) > TTTT Gallery
Old 05-31-2003, 06:21 AM
killer's Avatar
killer killer is offline
Proud to be Pinoy :)
under side view....... does the tranny looks familiar to you?
hehehe
Old 05-31-2003, 06:48 AM
killer's Avatar
beside a 3530 cellphone
i used a 35mm diameter wheels instead of the ol' monster truck tires
hehehe
Old 05-31-2003, 06:49 AM
killer's Avatar
front view......
hehehe
Old 05-31-2003, 06:50 AM
killer's Avatar
next
hehehe
Old 05-31-2003, 07:42 AM
killer's Avatar
Originally posted by Landy Man
Hey Killer
Nice work, I'm most impressed with your front axle. Do you have ball races in those hubs I can't quite tell from the pictures?
Those UJs are amaising, so far I have only managed to make one from brass but you make them in steel!
:ö: thanks Landy Man! , yes.. those hubs have ballraces in it!, it's the same size as the ballrace on a high-end 130 size motor cans, i found out that without the ballrace, a small motor such as the 7mm pager motor will have to work twice as hard just to turn the axles with the tires to carry the weight of the truck (complete with batteries and electronics installed) so gearing it low enough for more torque will help a lot ..... about those steel u-joint? i decided to make it from steel co'z i am not quite sure if the u-joints from brass would last , i'd rather spend hours making a steel one than fixing and replacing a broken brass joints on the truck everytime the front tire got stuck and try to pull itself out, though i haven't tried a brass joints yet, co'z i am quite happy with the steel joint performance, if you have watched the 1/87 truck video we made,in my own opinion, if i am using a brass joint i won't dare myself to run my truck on that coarse, this may damage brass joint quite easily, i've also proven the strength of the steel u-joint on my 1/32 Monster truck, (i hope you have checked that video too) though i'm using a bit thicker steel than the one used on my 1/87, but you could imagine the torture a small joint takes everytime it tries to turn a monster tire to climb a big obstacle like the thick yellow pages used on that video too which if i used a brass joint of the same size, in my opinion, i might have to fix it or replace a broken brass joint on the second or third run, but as of now all of my steel u-joints are doing a great job! and hope they'll last forever!
hehehe
Old 06-01-2003, 10:21 AM
killer's Avatar
tamiya bruiser chassis..
i found this chassis on the web... looks really cool
hehehe
Old 06-01-2003, 10:22 AM
killer's Avatar
Talking my chassis...
all i need now are some red and black paint..
hehehe
Old 06-04-2003, 05:19 AM
killer's Avatar
update
hehehe
Old 06-04-2003, 05:21 AM
killer's Avatar
next pic
hehehe
Old 06-04-2003, 05:22 AM
killer's Avatar
top view
hehehe
Old 06-04-2003, 05:23 AM
killer's Avatar
1/32 Tamiya Toyota Land Cruiser rally version... minus the decals and paint
hehehe
Old 06-04-2003, 05:24 AM
killer's Avatar
ArTiCuLaTiOn!!!!
hehehe
Old 06-04-2003, 05:25 AM
killer's Avatar
that's me!!... ooops that's my hand
hehehe
Old 06-04-2003, 12:42 PM
Overlander's Avatar
Overlander Overlander is offline
Overworked
I LOVE IT!!!!
_______________
I just like to build.
Micro RC for way over a decade
Old 06-04-2003, 04:07 PM
squeegee's Avatar
squeegee squeegee is offline
Tiny RC Expert
Absolutely positively 100% amazing! My favorite of all your wonderful work!!!!!
Losi 1/36 Micro-Desert Truck arch2b Micro-T General 2 11-11-2007 06:18 PM
xmods monster truck ts185r XMODS Mods and Projects 10 02-20-2006 03:40 PM
How to Build a 1/87 Scale RC truck a.k.a.TTTT Overlander TTTT 445 02-25-2004 06:15 PM
