Old 06-02-2003, 02:05 PM
Awaken's Avatar
Awaken Awaken is offline
Feh
Send a message via AIM to Awaken Send a message via Yahoo to Awaken
gears dont touch..
hey all when i dont have any wieght on the wheels they dont touch the gears...they can move up and down very loosely...any ideas on how to fix this? i think i removed the back wheel too many times lol..
Give me a moment in which I well never AWAKEN
Old 06-02-2003, 03:17 PM
viperkilla's Avatar
check if your gears are chipped or broken...this happened to my zip zap
Old 06-02-2003, 03:30 PM
Awaken's Avatar
Feh
no no the gears are fine they go real good when u push up on the wheels but when i hold it in the air they dont touch the wheels at all...its like loose..
i hate to go off topic but anyone know good places to buy those tanks that dont shoot?
Old 06-02-2003, 04:45 PM
metsrule119's Avatar
metsrule119 metsrule119 is offline
Actually, they suck^
Send a message via AIM to metsrule119
i have the same problem with my microsizer
1 Xmod w/ the works
2 Microsizers
1 Zipzap
1 Zipzap SE
1 Toy East Mini Cooper
1 Precious Clone
Old 06-02-2003, 04:56 PM
Awaken's Avatar
Feh
yeah it runs fine but if u get it on a bump or something it kinda strips at the gears... im thinking on glueing under the axel so its kinda permetly in there but at least it wont be loose...? i tryed putting paper and stuff around the axel but then all it did was make the wheels not roll..
Old 06-02-2003, 05:13 PM
Racer9's Avatar
Racer9 Racer9 is offline
Tiny RC Pro
You know the slot by the back axle? The one you can see from rear view? Stick the wide end of a toothpick in it. It helps alot. Trim pick so it doesn't hang off back.
Old 06-02-2003, 05:20 PM
crazydave's Avatar
Garage Rocker
Do a search for "JB Weld", and you should find something from Hogjowls telling you how to use JB weld to hold your axles in. It's actually a good idea, and I'll probably go that route myself, eventually, but for now here's a temporay fix, that has worked out great for me.
I used a piece of the sprayer tube from WD-40, and widened the axle slots with an exacto knife, until the slots were large enough for the tube. Then I super glued a bit of tube into each slot. Originally I took a wheel off and inserted the axle through the tube, but one time when I wanted to take the wheels off to get some hair, I just cut a little piece out of the bottom of the tube, and it still holds it snug, and is removeable too.
When I first did this, the axle was tight in the tube, so I coated it with some Green Slime (Teflon based grease), and used my dremel to spin it, and break it in. Now the gear mesh is super smooth, and quiet.
Old 06-02-2003, 05:58 PM
Awaken's Avatar
Feh
cool thanks for the info dave and racer9
wow racer 9 i cut a little piece of the end of the toothpick off and put in over the axel and it worked perfect..i also glued the toothe pick on place! works graet thanks.
Old 06-02-2003, 06:39 PM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
ya i did that with the tube from a qtip and it improves stock but just gluing the axle in gives a much tighter tolerance and really its easier to do.
Old 06-02-2003, 06:57 PM
Lord_Nick_D's Avatar
I cant stop modding
what also works is the match mod or something like it
I did a variation of it before it came out and it just holds the axel in nicely and because it is flexable it keeps the perfect tension between the gears it you set it right
Old 06-02-2003, 08:04 PM
Awaken's Avatar
Feh
lord nick ill have to try that one some time thanks
Old 06-02-2003, 08:17 PM
Awaken's Avatar
Feh
heres a pic (sorry so crappy) of how it worked from what racer9 showed me:
Old 06-02-2003, 09:45 PM
Fent Fent is offline
Send a message via AIM to Fent
i had the same thing got mad but i took a lighter and melted the middle of the slot and now its fine dont have pic or i would show u!
Old 06-03-2003, 02:23 AM
Awaken's Avatar
Feh
im just staying with my good old toothpick it runs good so im happy..thanks racer9
Selling lots of gears and moters pain899 For Sale/Trade 19 09-30-2006 11:17 PM
Pinon gears. dje7447 Bit Char-G / MicroSizers 7 10-09-2003 04:52 PM
Tips for quieting gears NoPropMan Bit Char-G / MicroSizers 14 03-28-2003 12:59 AM
WTB/T for gears big-key For Sale/Trade 0 03-06-2003 01:19 PM
clone gears vs bit gears ? Mike the Great Bit Char-G Parts and Hop-Ups 10 01-19-2003 02:05 AM
