11-14-2003, 02:15 PM
Aligning the antena like a "real" car
1. Take a screw driver (Phillips) and twist it back and forth overtop where you want your new antena to come out of.
Poke antenna through the hole and your done.
Honk if you love peace and quiet.
www.RCmod.com Great Site!
11-16-2003, 07:57 PM
Originally posted by Clergy
Not so much a mod, but something funny I noticed as I just bought my first MicroSizer. On the instructions it says "Do not put it into a fire." ......duh
ROFL
11-17-2003, 06:50 AM
Popping in a fast motor and rear takes about a minute.
Peeling the crappy stickers off of a clone takes about a minute.
(If you have some gunk-off)
11-18-2003, 04:23 PM
It's Really Fast!
If you have a soldering iron, there is a capacitor on the circuit board that limits travel. see http://tinyrc.com/qfm/racing/mod_08.htm#29 for details.
12-12-2003, 10:30 PM
If you have a "Modifier", you can screw a nice big fat muffler onto your BCG. You need to take the motor clip and motor out. Using a small black screw that came with the modifier car, you can screw a muffler onto one of the two pre-existing hole on the back chasis of your BCG or clone. Looks hella tight and best of all, if you bought a modifier that came with two muffler, you can have twin exhaust coming out from behind. Each muffler should take you 20 seconds, 5 seconds for the motor, and two seconds for the motor clip. Putting back the body should take 5 seconds.
Total mod should take 20+20+5+2+5= 52 seconds.
Have fun
I have developed a differential for the Bit Char-G.
01-03-2004, 03:13 PM
take a spare pare of back tires put em over your front tires and there u go full size wheels
hehehe
01-09-2004, 01:28 AM
I tried doing the wheel thing once with a set of spare zz tires and found they rubbed when I turned. Have to shave away some body to do that one
01-11-2004, 04:39 PM
Extending Range
Hi, my name is kyle and i just signed up for this website yesterday, because I enjoyed everything this website has to offer. I especially enjoyed the forums, and "how to do modifications" pages. So here is a big thank you to Tiny.
Now to bussiness........
This is a simple 1 minute mod dfor all bit char g, and microsizer's that will increase your cars range.....
1.) Take off the axle, and spur gears.
2.) Take off the plastic cover the protects the circuit board.
3.) Tilt the circuit board up so that you can see the wires and battery underneath.
4.) Find the antenna, ( white flexible wire) now gently without harming any other wires, untie the knot in the wire. (see picture below for help)
5.) Replace the plastic cover, and make sure that there aren't any snags.
6.) Now because the wire is longer you may want to spiral it around a paperclip or something for support.
01-13-2004, 03:26 AM
Shattered Windows
The first one on here was the black tape window tinting, I personally like the shattered glass look...
Krinkle up some tinfoil and tape it tight to the windows.
02-02-2004, 07:23 AM
take the shell off. it's about 1/4 of the total weight of stock bits. increases take off and top speed!
