Old 08-09-2003, 03:45 PM
bjv5 bjv5 is offline
Removal of Pin
How do I remove the pin from the knuckle and hub on my spec2?
Old 08-09-2003, 04:41 PM
gertman's Avatar
gertman gertman is offline
It should just pull straight out with little force. Which model do you have a Spec 1 or 2 ?
-Engineering Manager
Old 08-09-2003, 10:06 PM
It is a spec 2 and what do I pull it out with?
Old 08-10-2003, 12:08 AM
gertman's Avatar
Do you mean one of the pins that the front wheels rotate on? I believe needle nose pliers should do the trick. Please, let me know if it works.
Old 08-10-2003, 10:33 AM
Okay thanks!!
front wheel removal? bitter being ZipZaps SE 4 08-10-2004 01:10 PM
Light lens removal? (paint prep) Exaran XMODS 1 12-30-2003 03:45 PM
Pinion Removal ? webpilot XMODS Mods and Projects 13 12-04-2003 07:48 PM
Rear Axle Removal Nathan Epoch RC1/43 2 06-18-2003 10:25 PM
How do you remove the front pins from the steering knuckle tjmon Bit Char-G / MicroSizers 14 02-17-2003 03:55 PM
