07-16-2002, 03:43 AM
TinyRC Chief
Butler's Bitty
Couldn't post a pic until I modded something.
I have lowered the front. I cut the piece of chassis that holds on the body at the front clean off. Re attached it to the chassis lower down. Not sure how I am going to do the back yet.
It turns in better now believe it or not!
07-16-2002, 07:32 AM
I luv LEDs
Here's what i plan to do to lower the entire body.... I'm going to shave the slots in the body lower with a dremel.... Then i'm going fill the hole with putty, then dremel the slot again. So the slot is going to lower the body.... sound good? or should i throw away the idea?
07-16-2002, 07:47 AM
Butler, very cool!!!
07-16-2002, 07:59 AM
TinyRC Chief
Thanks,
Wedge,
I am going to try that for lowering the back. You can't modify the back the same as the front because the heat sink is clipped in.
I am not sure I have a tool that will cut a slot that small.
Oh BTW you have to move the slot UP to lower the body.
07-16-2002, 08:21 AM
Redneck Drifter
that might work, but only if you use a body that has a big roof. if not when you lower it, the clear plastic case will hit the body. you might have to do a little dremeling on the car, as well as the body
07-16-2002, 09:24 AM
TinyRC Chief
I don't think thats is an issue on any of the cars I have seen.
07-18-2002, 05:49 AM
TinyRC Chief
I take that back
The roof has enough height, but not width. D'oh
And I have made I right mess cutting the new slot in the back
New bodies please.....
Not sure what to do now.
07-18-2002, 08:12 AM
Oh no! You can always reattach the tab in the same place? Or get yourself some shiny new DansAm bodies!  Either way, I hope you get it fixed!
07-18-2002, 09:43 AM
TinyRC Chief
Tinyrc,
The tab is fine. I moved the tab on the front with great success, as shown in my pic. I couldn't move the rear tab because it holds the heatsink. So in my infinite wisdom I decided to dremel another slot in the back of the body higher up to lower it on the car. I basically did it too high and the body won't go lower enough to attach it because the chassis wedges itself first.
The back of the car body has 2 slots and one of them is wonky and in the wrong place. I wonder if my local car body repair shop will look at it.
Anyway it a good reason to buy some modelling stuff and start a customer paint job
07-18-2002, 09:45 AM
Redneck Drifter
oh well, at least bodys only cost a shade under ten bucks. you can always try again
07-24-2002, 07:17 AM
TinyRC Chief
Where can you get the bodies from?
I have got some modeling putty and paint now, so I shall be making some repairs and hopefully it all nice again
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
itty bitty rail
jco |
Bit Char-G / MicroSizers |
13 |
07-03-2003 07:18 PM |
