-   Bit Char-G Gallery (http://tinyrc.com/forums/forumdisplay.php?f=12)
-   -   Butler's Bitty (http://tinyrc.com/forums/showthread.php?t=278)
btlmr 07-16-2002 03:43 AM
Butler's Bitty
1 Attachment(s)
Couldn't post a pic until I modded something.:D
I have lowered the front. I cut the piece of chassis that holds on the body at the front clean off. Re attached it to the chassis lower down. Not sure how I am going to do the back yet.
It turns in better now believe it or not!
Wedginator 07-16-2002 07:32 AM
Here's what i plan to do to lower the entire body.... I'm going to shave the slots in the body lower with a dremel.... Then i'm going fill the hole with putty, then dremel the slot again. So the slot is going to lower the body.... sound good? or should i throw away the idea?;)
tinyrc 07-16-2002 07:47 AM
Butler, very cool!!!
btlmr 07-16-2002 07:59 AM
Thanks, :)
Wedge,
I am going to try that for lowering the back. You can't modify the back the same as the front because the heat sink is clipped in.
I am not sure I have a tool that will cut a slot that small.:(
Oh BTW you have to move the slot UP to lower the body. :p
ViperKid 07-16-2002 08:21 AM
that might work, but only if you use a body that has a big roof. if not when you lower it, the clear plastic case will hit the body. you might have to do a little dremeling on the car, as well as the body
btlmr 07-16-2002 09:24 AM
I don't think thats is an issue on any of the cars I have seen.
btlmr 07-18-2002 05:49 AM
I take that back:(
The roof has enough height, but not width. D'oh
And I have made I right mess cutting the new slot in the back:(
New bodies please.....:p
Not sure what to do now.:rolleyes:
tinyrc 07-18-2002 08:12 AM
Oh no! You can always reattach the tab in the same place? Or get yourself some shiny new DansAm bodies! ;) Either way, I hope you get it fixed!
btlmr 07-18-2002 09:43 AM
Tinyrc,
The tab is fine. I moved the tab on the front with great success, as shown in my pic. I couldn't move the rear tab because it holds the heatsink. So in my infinite wisdom I decided to dremel another slot in the back of the body higher up to lower it on the car. I basically did it too high and the body won't go lower enough to attach it because the chassis wedges itself first. :mad: :(
The back of the car body has 2 slots and one of them is wonky and in the wrong place. I wonder if my local car body repair shop will look at it. :p
Anyway it a good reason to buy some modelling stuff and start a customer paint job
:D
ViperKid 07-18-2002 09:45 AM
oh well, at least bodys only cost a shade under ten bucks. you can always try again:)
btlmr 07-24-2002 07:17 AM
Where can you get the bodies from?
I have got some modeling putty and paint now, so I shall be making some repairs and hopefully it all nice again ;)
