Go Back   TinyRC.com > 1/64 and Smaller > ZipZaps, ZipZaps SE > ZipZaps Mods and Projects
Old 09-03-2004, 02:32 PM
mshkttck's Avatar
mshkttck mshkttck is offline
Question SE battery swap! charging Qs
I am about to swap an se battery into a normal ZZ. I will also make a stand alone charger using an extra controller. Would the swapped se battery be able work with the charger's 2 AAAs directly? Should I remove a AAA? Is there anything else I should do or know before I try this? I recently put another zz out of its misery attempting this, and I really dont want to ruin a new one.
thanks for your time
Old 09-04-2004, 05:50 PM
Azimov's Avatar
Azimov Azimov is offline
I process, therefore I am
You need to use 4 AAAs to charge the SE battery for the time limit built into the charger. Or, you can use two AAAs and charge twice as long.
Old 09-04-2004, 06:03 PM
mshkttck's Avatar
I was talking about making a stand alone charger by removing the pcb.
Old 09-07-2004, 06:09 PM
DailyDriver
heres my stand alone.....and a dual cell
just an idea. i built this out of a zip contoller cap. the led is just for fun and is not needed.also 1 se battery wont give you much of a difference as two 1.2v as well wont last as long, weight balance, i prefer the extra weight in the back, 2.4 internal swap alows it to be really light in the rear, unless mounted perp. to the engine.
Old 09-07-2004, 06:10 PM
DailyDriver
how do i add more than 1 pic...
and change its size as i am sorry for the hugeness of these pics.
Old 09-07-2004, 06:12 PM
DailyDriver
one more
last on sitting on top of my coffe pot just fneeded the black for clarity the red blue buttons in the back have nothing to do with the charger.
Build a Stand-Alone AC (or battery) charger SuperFly Tips, Mods and Reviews 0 09-03-2003 07:22 PM
FYI:Motor Works (clone) charging base will charge dual and triple battery setups. Clint Bit Char-G / MicroSizers 0 02-17-2003 04:09 PM
More powerful steering for 2-cell mod? bonus: faster charging for dual battery mod Chris Bit Char-G Mods and Projects 1 11-23-2002 07:24 PM
