View Poll Results: how far does ur car drift?
1-4in
10 |
50.00% |
5-8in
5 |
25.00% |
9-12in
0 |
0% |
over 12in
1 |
5.00% |
doesnt drift
4 |
20.00% |
01-22-2003, 03:06 PM
drifting
01-22-2003, 08:20 PM
da da dum da dum da da
you cant drift with a bit char-g what you have been considering drifting is powersliding you would need brakes,proportional steering and acceleration and a lot more. and it wouldn't matter how far it can drift because if you drift you should be able to control it around the whole corner no matter what the size
"Do you want a new Bit Char-G
WELL I DO TOO!!!!!!!!!!"-me
"i'll let you win, on one condition beat me"-me
racing down akina
01-22-2003, 08:40 PM
The Lexan Body Pro!
Nah u can drift em, but not as good as u power slide them. i know with mine, i turn the wheel and then let of and i can drift it few inchs.
~~~Bash it Bash it Good!!!~~~
01-22-2003, 09:07 PM
actually i was more on the line of drifting forward
01-23-2003, 05:19 AM
www.d1gp.com
oh jeez....not these "Drifting" threads again...
well i wont call it drifting, its more like "slide till i stop, and then go again"...that isnt drifting at all
01-23-2003, 07:24 AM
O.o well any1 can slide
07-19-2003, 09:40 PM
TinyRC addict
drifting
i like to see my car drift pass my opponents car in the 1/4 mile....then as he slings me his trading card..i like to see it drift in the air...i know what ya you gys mean about the drifting ..sometimes..mostly by chance..you can get a drifting motion in a turn..even if it is for only like 1/2 inch or so.
i love clones
07-19-2003, 11:01 PM
drift in a 1/4 mile? WTF u can only drift corners, thats the proper way of "drifting" anyways
07-19-2003, 11:28 PM
Camera springs
Yes, more drifting. You can drift. It's just a little harder with a micro.
Key components:
Good torque
Non sticky tires in the front and not so sticky tires in the back.
(If you correct the the problem of the front being heavy in the bit, then you can use same tires on all 4s)
The idea:
Loose some (not all) traction on all 4 tires. The front needs to give first, then the back. Otherwise you'll just spin out. (A well balanced car drifts all 4 wheels at the same time. But, bits aren't exactly balanced like a real car)
The method:
Before you start the turn, slow down a little. When you start hitting the turn, put the mini pedal to the mini metal. Practice.
My thoughts:
Drifting can be usefull, but not as usefull as people think. It can slow down your overall run time. Plus for these cars, you can't really control the radius all that well. I usually just get a basic radius, practice it, and stick with that. If a turn doesn't correspond with that radius, then I don't do it. To really drift effectively, you would need a stiffer front steering system. And yes, propo would be extremely helpfull. Also, try to get some of the weight off the front wheels. Tomy didn't have in mind the idea of racing when they made these cars. They are front heavy. That makes the front tires stick more.
07-19-2003, 11:32 PM
i think they have a heavier back because all you got up front is steering. form the middle to the back its all heavy electronic parts and a motor and a battery
07-19-2003, 11:41 PM
Camera springs
Yes, but the motor isn't all that heavy (some are). Think of the magnet, copper coils and all the extra plastic in the front. The motor and heat sink are mostly aluminum. Aluminum is pretty light. Also it varies a little depending on what body you use. For example, a supra has a little more weight on the front end then most.
07-20-2003, 12:25 AM
yeah because it has a huge nose and an ugly body kit
07-20-2003, 12:50 AM
0reZepyT
i think he means how far does your bit coast after u let go fo the throttle. some motors act like a brake when u let go of the throttle while others free spin so well that u can go quite far wihtout any throttle input
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
07-20-2003, 01:02 AM
I have a beach ball...
Drifting IS powersliding. There is NO difference whatsoever, and anyone who tells you different is lying.
'65 Ford Mustang
All the RS goodies
Becoming a donor car for:
'04 Ford Mustang Cobra
07-20-2003, 01:28 AM
Camera springs
Oops. Well, in that case. My dual cells with nmhd are the heaviest. They'll drift about 3ft+ easy with a good start. Maybe about 5ft~7ft at full speed. They are pretty loobed up most of the time too.
