Old 07-16-2003, 02:00 AM
dmoh7 dmoh7 is offline
Steering Prob Please Help
I just recently got a clone of a bitchar-g ... lxx char-g yellow supra---- it was workin great but then all of a sudden when i tried turnin on low speed it didnt have enuff power to keep goen.... like itd start of fine at first then slow down then stop but it runs fine in fast mode.... anyone know what to do????
Old 07-16-2003, 02:51 AM
SkyLiNEz 4-eva!
ummm, lets see...do you have any mods on the front wheels of the car? check out my thread "steering problems? i have the answer!"
Old 07-16-2003, 03:31 AM
havent modded it at all... and that lil dial on the bottom.... is on the center.... ive checked it and didnt understand.... all my car duz is just turn to the right slightly...
Old 07-16-2003, 03:44 AM
SkyLiNEz 4-eva!
have you undone the steering column and looked at the magneto discs, wires and magnet? the magnet is probably off center.
Old 07-16-2003, 03:45 AM
uh how do i do that
Old 07-16-2003, 03:49 AM
SkyLiNEz 4-eva!
move the chip to the back of the car. there's a little screw in the front. undo it. pull off the clip and i will tell you what to do from there.
Old 07-16-2003, 03:50 AM
that sounds really risky... do you have yahoo or msn... email me at dmoh7@hotmail.com or d_moh7@yahoo.com
Old 07-16-2003, 04:47 AM
yo i emailed you like 10 times wuts the deal?
Old 07-16-2003, 04:48 AM
SkyLiNEz 4-eva!
i dont know my email is f'd up real bad, man!
Old 07-16-2003, 07:31 PM
boho's Avatar
boho boho is offline
Camera springs
It is risky if you're not careful. But it's not all that bad. Although I would check the gears in the back first. If the back wheel axle is loose, then it probably creates alot of friction when it's turning, which creates drag. I don't mean loose like it comes out easy, I mean loose like it slides left and right easy. If so take the back wheels off, grab a small hammer or other useable object and gently bang the wheels closer to each other.
Opening the inside of the steering box is more for unequal steering problems.
Old 07-16-2003, 07:53 PM
thanx alot i think that might be the problem cuz my wheels are kinna loose when its off the floor it duz slip about 2 mm's to the side maybe... how do i take the gears out?
Old 07-16-2003, 07:56 PM
the rear axle *** how do you take it out
Old 07-16-2003, 10:15 PM
boho's Avatar
Camera springs
Well, this part is highly technical! pull it.
Sorry, not making fun of you. Take your thumb and your forefinger. With your thumb on one wheel and your forefinger on the other, pull. Be carefull not to bend the axle too much.
Old 07-17-2003, 05:22 AM
SkyLiNEz 4-eva!
you also might want to see if you can fit something about a half-a-millimeter-thick piece ofplastic or something in there.
Old 07-17-2003, 12:21 PM
i got it out!! i was hesitant lol... but it got out and i hammerd at it... and it got shorter and i put it in... no more side to side, but the car still goes to the right a bit.
Steering prob Racer240 XMODS 3 11-17-2003 05:57 PM
steering prob Char-g Ace ZipZaps SE 3 10-11-2003 02:59 PM
New Steering prob... BigPimpin ZipZaps 1 01-08-2003 09:58 AM
