-   -   can u put dual batteries in microsizers (http://tinyrc.com/forums/showthread.php?t=4549)
zombiebaby 12-08-2002 11:22 AM
Can u have 2 batteries in microsizers and how do wire it ?:D
Dratheus 12-08-2002 11:33 AM
Of course you can install two batteries!! You'll need to solder a wire from the negative terminal on the car to the negative side of the second battery. Then solder a wire from the positive side of the second battery to the negative side of the first battery. You can leave the positive side of the first battery like it is. Be sure to put an insulator in between the negative contact on the car an the negative end on the first batteryso they don't short out the second battery. As an insulator you could rap the neg. side of the first battery with electrical tape over you solder connection. This mod can be done with 2 NiCD or 2 NiMH batteries. Just be sure you don't mix a NiCD and a NiMH battery. For a little more visual aid, try www.questformadness.com Have Fun!!
zombiebaby 12-08-2002 12:54 PM
whats the diffrence does the batterie type make?
Dratheus 12-08-2002 01:14 PM
The NiMH batteries hold a longer charge than the Nicd do.I also believe they pump a little more power to the motor. I bought a small dual battery mod kit off of Ebay. It contained 2 NiMH, extra hook-up wire, a 4 AA cell battery pack, heat shrink for the second battery, and a NOS sticker..hahaha. Also for a dual battery mod you would be better off removing the charge station from the controller, and rigging it up to another power source. (ie: the 4AA cell batt. pack) The 2AA that are in the controller don't supply enough juice to properly charge a dual battery car. You won't have the timing LED to tell you when to take the car off of the charger so don't charge the dual batt. car on a stand alone charger for more than 2 minutes.
delaroca 12-08-2002 06:18 PM
drath,
you've just answered a question i was asking in another post. I couldn't get much charge into my 2.4v dual setup from the 2xAA controller. It's a 4 batt stand-alone charger 4 me.
thx 4 info
rabbitsperm 12-09-2002 08:59 AM
sweet
DavidDeLaurier 12-09-2002 11:38 AM
You have to have the 4AA batt charger or it will not work well.
PS: WOW, your name is really funny, LMAO!!! - - - "RabbitSperm"
Dratheus 12-09-2002 11:57 PM
Del,
No prob.! I'm glad I could inadvertently help! :D
