ok
Sorry, on the Team Orion RS4 lug nuts, the colored ones the nut driver size is 4.5mm.
Good luck finding one though. I had to buy a 1/4" nut driver and a 4.5mm Matco socket....Snap-On also sells these, about $8-15 though each. |
i sure wouldn't mind a set of metal lugs right now. A friend and I were racing, and I didn't realize, but one of the lugs on the wheels was completely stripped. Mid-driving on a sharp turn my wheel rolledo off, LoL.
Not that tight but they are Nylon lock nuts, so you cannot remove them with your fingers.
And you cannot put them on with your fingers. Non-locknuts on a 6 cell or more(motor other than a 130, etc.) will spin the nuts off and sling them right off the axle. |
FYI All, we'll soon be offering TRC Lock Nuts, as well as Wrenches! :cool:
btrc |
Re: ok
The one thing I have noticed about buying these nut drivers is that you need to have a bench grinder handy, as the driver is too thick to fit in a deep-dish wheel. With stock XMods wheels, it may work as it is, but with Mini-Zs, I had to grind down the outside a bit so it would fit in the wheel. Not a big problem for me, it only took about five minutes to do, but if you don't have a bench grinder or have access to one, then you may have a problem. Quote:
hmmm.....
Interesting about the driver not fitting.
Actualy I already had a 1/4" nut driver in my toolbox I never use, a craftsman one that came with something along time ago. Also my one neighboring technician had a 4.5mm deep well Matco 1/4" socket. He said "Here, I will never use that size. Have it." So I lucked out. But I did look at prices and see who on the trucks had them in a shallow well, but the deep works great for free so I said I only need a deep really.:D |
the first thing i did was run down into my dads workshop and i stole(borrowed) 4 aluminum nuts they work great. i hate the "nylon" lugs they strip to easy and crack.
| All times are GMT -5. The time now is 09:11 AM. |
