Boho? yeah, he does good work when he makes post. email me man i just cent u one.
i soldered it... but the hole woudnt show, it would show then get covered again. so i didnt manage to get it trhu. And worst of all... now i have a an even bigger problem....the red white and yellow wires of the pcb got deattached.... is there any way i can fix it ? Also the tiny thing beside the wire on top of the pcb chip got moved a lil bit... is that ok
1 Attachment(s)
that thing got moved..... and the wires got disconnected should i try and reattach the wires? And is it ok that that thing got moved wiht the soulder gun a tiny bit?
You need to get some solder braid to soak up the solder while it's still hot. You should be able to get some from the place you got your iron. As for all the wires becoming unsoldered, you've got one hell of a project on your hands there. From my experience you only get one touch of the iron before you start melting the other wires on the board. Just take your time and resolder them all. Whatever you do, don't get impatient. There are a lot of little things that can and often times will go wrong when doing things like this.
k... but how do i know which wires go to which lil metal thing.... does it matter?
1 Attachment(s)
and this is the thing i was telling you that got moved
man, your car is a real mess. get a wiring diagram or something or else youre gonna have to buy a new chassis.
| All times are GMT -5. The time now is 08:04 PM. |
