Old 11-01-2002, 02:14 PM
CopeCowboy1 CopeCowboy1 is offline
Question Burn Out?
I ordered my Bit yesterday morning and I also ordered a 3.8 motor and i was wandering if the 3.8 is goign to burn up the electronics or if it will burn up? I'm worried that it might be over powering anyone know? Also what upgrade parts should i get to go with my 3.8 tires, suspension. etc... Please all tips are appreciated!
Fresh Cope... It Satisfies!!!
Old 11-01-2002, 05:02 PM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
Send a message via AIM to MTL
you can never have enough powerful motor to make your bit go into flames..
Old 11-01-2002, 06:40 PM
NorCalCoug's Avatar
NorCalCoug NorCalCoug is offline
l33t camber wizard :)
Having a faster motor will not harm the electronics in any way. Putting too much voltage in the car will (I know from experience... ) but the stock battery can't pass more than 1.2v to the PCB, and consequently to the motor. So.. don't worry dude, pop that baby in and enjoy!
Old 11-01-2002, 07:55 PM
E)(pul$ioN E)(pul$ioN is offline
Founder of EaT RiCe Squad
Send a message via AIM to E)(pul$ioN
If you want regular driving, your best off with the 2.2. I personally can't drive regularly with a super fast 3.8. I also personally think there is no need to cuss.
A student that doesn't like school.
Old 11-01-2002, 09:10 PM
Tires?¿
What kind of tires shoudl i put on it i see the tire set do i put the hard slick ones on it or the blue ones or the medium ones with the lines down the middle???
Old 11-01-2002, 09:12 PM
Speed-D Speed-D is offline
TinyRC JUNKIE!
Surface, surface, surface.
What surface are you mostly running on?
Speed-D
I never drive faster than I can see and besides that, it's all in the reflexes anyway.
Old 11-01-2002, 09:47 PM
TinyRC JUNKIE!
Thumbs up Rules of thumb
If your rear tires are "grippier" than the front your turns will be wider. If you put "grippier" tires on the front, your turns will be tighter. However if your motor is too fast this will induce flips or barrel rolls.
Speed-D
Old 11-01-2002, 09:57 PM
So Grip is the way to go
So i shoudl go with the grip and keep the stock 2.2 grip on the front and slicks on the back for normal driving then when i drag i shoudl go with my 3.8 with slicks on the front and back and not make any turns! Thanks for the help man
Dual battery mod will burn out motor? Chris Bit Char-G Parts and Hop-Ups 9 03-12-2003 07:17 PM
burn outs SiRcyrus Bit Char-G Mods and Projects 7 03-04-2003 11:32 PM
Whould a 1.2V/1500mAh/Ni-Cd Solder Tab Battery burn up my Zip Zap Car??? jutte07 ZipZaps 3 12-29-2002 01:07 AM
Do the 2.6 and 3.0 motors burn out at all?? Mellow Yellow Bit Char-G / MicroSizers 5 09-22-2002 12:09 AM
