11-08-2003, 06:51 PM
I like the revised plate. Seeing most of the scratches are at the rear of my skyline. I have a couple of questions. What did you use to drill the holes and create the spaces for the body clip and power switch? Also do you notice any difference in the driving performance of the vehicle? Does it run slower or handle differently?
Xmod Skyline
X Speed Mini Z Motor
9 tooth Drag gears
6 cell mod
AWD
Blue (stiff) Rear Suspention
Red (soft) Front Suspention
Hard Slicks all around
RS Bearing Set
11-08-2003, 07:02 PM
Acura RSX
Wow thats great Bad Company! Man, do you ever stop modding?
11-08-2003, 08:34 PM
viperkilla, Only when I go to bed. The car handles all the same. The added weight is very little, hardly none at all, plus this car has the 2 extra cells. I drilled pilot holes in the corners and used a dremel and hobby knife to cut the openings.
11-11-2003, 02:06 PM
I R r33t Hick
Thanks for the idea BC,
i just got done making my first one, i found a pack of 10 sheets for 1.50 at home depot and i just made one..
here is the under shot.....
here is the front....
here is the rear....
11-11-2003, 02:09 PM
Acura RSX
This idea probably doesnt fit in this thread but, I have tried using a skid plate made of the zip zap box. I just cut out a piece that would fit under the chassis of my XMOD and it works great.
03-29-2006, 07:55 PM
Bad company,
you think you could design one for the mustang evo frame,
i could draw it in AUTOCAD for you. love all your work, keep it up
04-02-2006, 10:02 PM
wow this skid plate is niiiiiiice.
i was thinking about making one for mine from a soda can!
hahaha, like cut it, then flatten it... and all that.
man, that looks really nice though, good work.
04-24-2006, 02:24 PM
11-23-2006, 04:50 PM
nice i like the clean look
if its fast flamable and deadily count me in
my cars infinity g35 and a hummer in the shop
11-23-2006, 08:39 PM
Consider this your last warning moddsmann, read over the rules, this is clearly bumping an old thread without just cause. Again, the new rules along with all the forum rules can be found here: http://tinyrc.com/forums/showthread.php?t=22744
Thread Tools |
Display Modes |
Linear Mode
