Old 03-19-2010, 09:47 PM
arch2b's Avatar
arch2b arch2b is offline
TinyRC & Mini-zRacer Fan
X-Power
NanoTrax is the worldwide retailer for X-Power dNaNo parts. Any and all requests for information, availability, etc. should be directed to NanoTrax.
Product information and images courtesy of NanoTrax.
XP-Slick Tires for dNaNo
these are the slick tires for dNaNo from X-Power. they come in various compounds for both front and rear wheels. 25F 30F, 35F, 40F, 45F, 6R, 8R, 10R, 20R
XP-LED Light Kit
this is the X-Power LED Light Kit for dNaNo Auto Scale Collection (front headlights/rear tail lights). this light system comes with 3 separate “mode” sets each with its own function. it connects to the PC port on dNaNo and requires a bit of detailed installation to the body. we advise installation be done on a “blank” ASC body since installing the lights requires invasive internal installation. set contains enough light kits to equip 3 models. if you’d like NanoTrax to install a set for you, simply include an applicable ASC body with your order and e-mail me to let me know which mode you’d like to have installed.
Mode 1 = lights always on, front and rear
Mode 2 = front lights always on, rear lights illuminate on reverse only
Mode 3 = front lights on only on throttle, rear lights on in reverse only
note: the use of these lights will obviously redirect some battery power, thereby slightly reducing the performance of other parts using the power source (gyro, motor, etc). the lights are really cool and i use them when practicing but i wouldn't recommend racing with lights unless every participant is using them.
XP-LBD1 Portable Li-Ion Charger
this is the portable (lithium ion) battery charger from X-Power. need a portable power source for charging your battery when you’re at the track? charge this station’s internal lithium ion battery up and it can then be used to charge your 130mAh dNaNo battery for up to 10 cycles (200mAh, 7 cycles). it has an AC adapter that uses 1 of 2 ports (UBC/Firewire) available to charge it. for use with all available dNaNo batteries.
XP-Lipo 3.7V 200mAh Battery
this is the X-Power 3.7V 200mAh Battery for dNaNo. it can be charged with the standard dNaNo Lipo Charger but this version gives you almost twice the runtime and greater output. want the edge? this is it!
XP-SSG DPS Kit with LED
this is the X-Power SSG-DPS (Damper) with LED light for dNaNo. we’ve extensively tested this damping kit and it works just as well as any other available on the market but this one has a cool looking blue LED light giving the same effect as ‘neon’ light kits on full size cars. if you need damping, pick this up and get a bonus with that extra performance.
note: this item cannot be installed on models with an HM Chassis nor can it be installed on models with "low" profile type bodies without drilling a hole in the body to make space for the damper plate. if you're unsure of whether this item will fit your car, contact us before ordering.
XP-Ceramic Ball Bearings Set
this is the full, 3-pc. Ceramic + 4-pc. Steel Ball Bearings Set for dNaNo. it includes all normal bearings (6) plus one (1) meant for replacing the stock ball differential bearing. if you know anything about ceramic, you’ll know its friction coefficient is lower than stainless steel so this is an excellent upgrade as opposed to the stock or other available bearings for dNaNo.
X-Power HOT Motor for dNaNo
this is the optional high torque, modified “Hot” motor for dNaNo.
XP-SSGR Replacement Parts
these are the replacement/spare parts for the XP-SSG Damper Kit. this comes in handy if you break the mount or lose any of springs.
XP-YSP Y Adapter for LED Lights
want to use your led light kit and led damper light together? pick up this ’splice’ y-adapter that allows you to plug in both leads at once!
XP-Gyro Unit
this is the X-Power Gyro Unit (Gyro) for dNaNo. if picking up the original is breaking your budget, try this one as its an economical alternative with the same functions.
Old 03-19-2010, 09:53 PM
arch2b's Avatar
XP-ICS Cable
this is the X-Power ICS Cable for Mini-Z/dNaNo. use this cable to connect your model to your PC and modify servo response characteristics and the degree to which the gyro assists car functions.
XP-Screws
these are replacement screws & washers for dNaNo. these screws are slightly longer & thicker than the stock screws. the screw seats for your front suspension plates &/or body mount screws will eventually become stripped and the stock screws will no longer hold those crucial parts in place. use these in place of the stock screws in this case.
XP-Ceramic Diff Balls
these are the replacement ‘optional’ Ceramic Diff Balls for use with DNW103 Ball Differential Set for dNaNo. if you know anything about ceramic, you’ll know its friction coefficient is lower than stainless steel so this is an excellent upgrade for improving the performance of your ball differential. it comes in two (2) colors and each pack includes six (6) balls to completely replace the stock setup. note: the difference in color is only for convenience, there is no difference in performance
XP-AWHubs Aluminum Rear Wheel Hubs
these are the Aluminum Rear Wheel Hubs for dNaNo by X-Power. these are available in royal blue and forest green and are direct substitutes for the original brand.
XP-FSS Front Shock Springs
these are the X-Power front shock springs for dNaNo. it includes 3 pairs of springs (Soft, Medium, Hard)
Battery Discharger
this is the portable battery discharger for all types and brands for dNano
Five Star Wheels
these are the Five Star (aka Double Star) wheels (1 Pair) for dNano. they come in 4 colors and all sizes.
Mach Six Wheels
these are the Mach 6 (aka Double Six) wheels (1 Pair) for dNano. they come in 4 colors and all sizes.
Sun Spoke Wheels
these are the Sun Spoke (aka Ten Spoke) wheels (1 Pair) for dNano. they come in 4 colors and all sizes.
Horizontal Groove Tires for dNano
these are tires (1 Pair) with deep, horizontal grooves used to get traction on very slick surfaces. these tires can be used on either front or rear on linoleum or tiled floors so if you’d like to play with your dNano on this type of surface, you’ll need these tires. they come in 4 compounds and fit only FA/RA size wheels.
Motor Gears (7T,8T)
tired of buying a bunch of gears and tools just to get the one that you want? pick up the most commonly used racing pinion (motor) gears in this neat, simple, 2-piece set.
arch2b's Avatar
Screwdriver for dNano
this is the screwdriver with +00 size bit for dNano
Spur Gears Set
this is the optional Spur Gears Set for the X-Power Ball Differential Set for dNano. it includes 30T, 31T, 32T, 33T and 34T spur gears.
this is the optional Ball Differential Set for dNano. it comes with Ceramic Diff Balls pre-installed. this diff is very smooth and will require tuning with oils of varying thickness to attain optimal performance. it does not come with tools to dismantle it nor additional spacer plates. the best option is to use spares from other sets or thin washers to vary diff spring tension. i discussed tuning this way in my Diffs & Bearings video @ YouTube.
Pressure Plates
this is the replacement pair of Pressure Plates for use in the XP Ball Differential. these can also be used in the Kyosho Ball Diff for dNano. the material is smooth and allows for more slip, opening up options for use of oils with various thickness for tuning.
Spur Gears Set
Rear Spacer Set
this the Rear Spacer Plates Set for dNano. if you’d like to modify the height of the body or tune understeer/oversteer, these are ideal for that application.
Light Front Wheel Shafts
these are the Light Weight Front Wheel Shafts for dNano
Heavy Front Wheel Shafts
these are the Heavy Duty, Hard Front Wheel Shafts for dNano
Old 03-21-2010, 11:48 AM
I can vouch for the 200 MAH battery - works well, about 5-8mins extra runtime if charged using a better charger than the stock Kyosho d'Nano charger. I also have the lights and few other XPower things I will test over the next while.
I like how Xpower has filled the gap of parts and has generic substitutes for the grossly overpriced Kysoho parts (such as the rear hubs, batteries).
Wishlist? A 230 MAH battery (which evidently fits) and FOAM TIRES ...these cars need all the traction they can get on the rear.
Old 05-07-2010, 09:19 PM
MrNanoTrax's Avatar
shouldn't this be a sticky? also... pics of old and new items should be updated
Old 06-21-2010, 01:27 PM
MrNanoTrax's Avatar
Lightbulb
new item from XP: Screwdriver for dNano
Old 07-07-2010, 07:37 PM
MrNanoTrax's Avatar
new arrivals...
eAsy Adjust Ball Diff Conversion Kit & Pinion Gear Variety for use with XP Spurs
Thread Tools
Display Modes
Copyright ©2000 - 2024, Jelsoft Enterprises Ltd.
