12-23-2006, 10:30 AM
Tie Rods
First thing broken, and no replacements at the hobby shop, so i looked around my MGT spare box and found a piece of brass stock (slightly thicker than the tie rod material) i layed out the original rod on the brass cut it with scissors, and made some 00 (?) holes, and its working perfect
12-23-2006, 10:43 AM
OH YEAh
you can also make adjustable "toe in" rods, get a caliper and adjust accordingly, cause your measuring in sections of millimeters
01-06-2007, 10:58 AM
new tie rod material
you know the thin "tin" from the top odf the peanut cans, we all have at christmas? this matrial is perfect , but it only takes one solid hit and pretty much done, but i have a ton of the tin... everyone had peanuts or cashews over the holidays
01-06-2007, 10:40 PM
TinyRC Super Pro
Wow, you really like red...You can also make them out of zipties...
01-08-2007, 09:20 PM
lol, yes i just want my posts to look diffrent, was just watching some videos of boats on google, and seen a turbine boat..wicked
02-04-2008, 09:31 AM
The down side to zip-ties is that if you push on the front end, the suspension is a bit stiffer ( even with the screws a little loose). But, now when it hits bumps, the front end seems to absorb the hit better and stays on the ground.
I have a friend that is going to try "feeler gauge" ( very thin metal).
Has anyone found something that works better?
Gene Police: "Hey you! Get out of the Pool!"
12-25-2008, 09:16 PM
I thought that the susspension on the front was too hard when i got my micro dt, so i took some spare helicopter parts and made some ball linkages, fully adjustable toe in/out, no resistance on the shock, but am looking into oil shocks
Thread Tools |
Display Modes |
