Go Back   TinyRC.com > Manufacturers > RealTracks
Old 06-22-2009, 07:01 PM
RealTracks's Avatar
RealTracks RealTracks is offline
dNaNo aluminum wheels now available
Just a quick post here to let everyone know that the Aluma-Tech wheels are now available at http://realtracksonline.com/dnano_aluminum_wheels.html. These are the wheels Mike Ross has been working on for the Auto Scale tires. We are just facilitating making them available immediately for Mike and Aluma-Tech. Our wheels are in route now and we have not even tested them yet. You will have to change the offsets to use them. They are currently available and tested on the Mazda 787B and the Porsche 962. The required steering plate, knuckle, tie rod, and rear hub are listed on the web site for those two models. They can be used on any dNaNo that share the 787B & 962 autoscale tire dimensions, and have a steering plate of (4) or greater. The key is that they drop 3 levels of offset on the front and the 4 hub sizes on the rear. Refer to Technical Data Sheet 7 of this document http://www.kyosho.com/jpn/support/in..._OPLVol_10.pdf . If your adjusted offset is a (4) or larger you will not have to change the knuckle. If you go down to a (3) you will have to go to the "B" Knucke that reduces the amount of steering angle for the inside tire. Let me know if you have any questions on this.
Thanks
Miles
RealTracks RC Racing Systems
Old 06-22-2009, 07:50 PM
arch2b's Avatar
arch2b arch2b is offline
TinyRC & Mini-zRacer Fan
nice, i already have some sets coming i can't wait to get them on the cars and on the track.
Old 06-22-2009, 10:34 PM
arch, be sure to post your impressions when you receive them, they do look nice and the price is better than the $60 I thought they were for such a limited run item. I'm certainly curious to know if the fronts are any wider than the stock wheels also.
Tags
dnano, dnano aluminum wheels, realtracks
Copyright ©2000 - 2024, Jelsoft Enterprises Ltd.
