03-02-2006, 03:48 AM
22B STi, GSR Impreza
low, mean, and can get sideways any-freaking-time i want it to. "GSR", in case you don't know, is my little xmod team i started over at xmw. this car will have GSR decals at the very least, and maybe a paint theme.
the whole kit and caboodle...
and if anyone's interested, the complete specs of the car:
- gen 1 xmod
- iwaver 01 pro PCB
- iwaver blue subaru shell
- RS clear chassis
- cirrus cs-4.4 servo
- lithium-ion batteries
- vxb bearings, shielded, + wheel shims
- AWD, front ball diff, rear gear-type lsd
- 0 degrees toe, approx. 1 degree camber front and rear
- RS stage 2 motor, 9t pinion, white bevel
- gpm front cupjoints, rear cupjoints, rear wheel shafts, driveshaft holders, front knuckles, rear suspension arms, dampers, and motor mount
- CF driveshaft
- gpm delrin rims, 55 degree tires.
enjoy!
03-04-2006, 03:57 AM
03-04-2006, 05:30 PM
Color0,
Can you/ Did tou buy your PCB board seperatly, or do I have to go buy an Iwaver to get one?
Does the Iwaver PCB improve speed?
Was it easy to solder?
Thanks.
EDIT: Btw, I ******* love that car, nice job! Where'd you get that bodY? I can't find one anywhere!
2 ZZ's 1 ZZMT, 6 Xmods
03-05-2006, 01:55 AM
Thrasher
I think it gives you better control, and you get to use a better controler to boot. It may also be better for speed. I am sure the Iwaver body helps alot to lighten the load on top of it. I can bet it is more than just looking good.
Only if someone can do delrin gears for the gen 1 Xmods we would be all set, yea right. Just not enough people messing with them anymore, everyone is into the evos now.
03-05-2006, 03:01 AM
more torque, more throttle steps, more steering steps.
not that i need the extra torque, with li-ions and hard tires, but... it's a fun car to drive.
edit: al9spike, i got the iwaver as an xmas gift and decided i didn't like drifting an RM IW01. so it went into this project.
the iwaver shell is about 5g lighter (body perception scale...), but less top-heavy than an xmod shell. it's also very flexible, i can't forsee breaking anything off it anytime soon. i'm not that bad of a driver either, so i can probably keep off the walls well enough to preserve this body.
machining a new set of gears for the gen 1 wouldn't be too hard design wise, i simply have to find the right size gears for the bevel and the diff, plug them into my design program and make a .dwg file out of it. heck, i could probably design a better ball diff as well. but the cost of that's going to be so astronomically high i wouldn't start until i had at least 50 people interested.
03-05-2006, 07:27 AM
Oh, Sucks for me
03-27-2006, 04:49 AM
Thread Tools |
Display Modes |
Linear Mode
