Can you turn the neutral adjustment screw too much on these things?
It doesn't seem to be making a difference and the throttle constantly runs...
Is there any other way to adjust this?? I tried to take the controller apart to see what's happening with the neutral adjustment screw, but i couldn't get it apart (didn't want to break the steering wheel)...
.....If you take a small screw driver or an x-acto knife, you can carefully pry off the little cap in the center of the steering wheel. Under the cap is a screw to remove the wheel.
