Old 11-08-2003, 06:04 PM
colin4371 colin4371 is offline
PPG Co-Owner
Front suspension problems!
hey, ive had my xmod for a couple weeks now, and i just did the steering horn straighten out thingy mod so my skyline will track straight, but once i put it back together, i realized that the suspension would not give at all, and with a body on, the chassis sat on the ground. does anyone know what might be wrong with it? do you see anything wrong/missing/ bent in the pics?
Old 11-08-2003, 06:10 PM
PPG Co-Owner
another, sorry for it being so big...
Old 11-08-2003, 06:39 PM
Viper966 Viper966 is offline
Send a message via AIM to Viper966
one of ur shocks appears to be stuk... try taking it out and pulling it in and out...
Old 11-08-2003, 06:51 PM
viperkilla's Avatar
Acura RSX
Or if that doesnt work, purchase the spring upgrade kit and see if that works.
Old 11-08-2003, 09:31 PM
txbart txbart is offline
Great macro shot of the front suspension tho. IS that a digital or regular film camera?
Old 11-08-2003, 10:53 PM
4G63T's Avatar
4G63T 4G63T is offline
got boost?
looks like digital to me
All Wheel Drive=Fun!!!
Old 11-09-2003, 02:58 AM
Hudson5150 Hudson5150 is offline
Send a message via Yahoo to Hudson5150
Try filing and sanding out the inside of the shocks just a bit. Put a dab of grease on the shocks shaft. Also the spring may have been damaged. Purchase the suspension kit if you can if not, try pulling the spring a bit till it gets its bounce back.
Xmod Skyline
X Speed Mini Z Motor
9 tooth Drag gears
6 cell mod
AWD
Blue (stiff) Rear Suspention
Red (soft) Front Suspention
Hard Slicks all around
RS Bearing Set
Old 11-09-2003, 05:57 PM
PPG Co-Owner
both springs and shocks are in good condition, its just that the suspension will not travel at all. it looks like it has something to do with the screws that hold the knuckles on.
p.s. it is a digital camera
Old 11-09-2003, 07:23 PM
slugbugg slugbugg is offline
I KNOW NOTHING!!!
colin4371, so the left shock works ok? it looks kinked in the photo.
Take both shocks off this will help you see whats binding or loose.
Take the front chassis top plate off so you can get a good look at the front end and make sure the tierod is on correctly.
After doing those things look closely to see if the front suspension supports are screwed down properly and in the exact spot they need to be in.(the left one looks like it is raised a bit)
Old 11-09-2003, 08:06 PM
I have a beach ball...
Just a quick observation... It looks like you may have put the knuckles on the wrong sides. Try switching them.
'65 Ford Mustang
All the RS goodies
Becoming a donor car for:
'04 Ford Mustang Cobra
Old 11-09-2003, 08:11 PM
an6e1o82 an6e1o82 is offline
Send a message via AIM to an6e1o82
maybe the mounting screws are too tight. I had mine do that when i over tightened the two screws that hold my shocks on. I losened them a bit and they work perfect again.
Thread Tools
Display Modes
Mounting Mini-Z bodies on Xmods neurokinetik XMODS Mods and Projects 18 12-28-2005 06:13 PM
Front suspension in rear T Man XMODS Mods and Projects 14 06-27-2005 06:35 PM
better front suspension springs for SE? daver ZipZaps SE 1 01-22-2005 08:54 PM
more front suspension travel theone&only.... ZipZaps Monster Truck 0 12-27-2004 12:55 AM
custom front suspension complete for 1:16 MTL Auldey (All) 2 12-05-2002 05:52 PM
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
