Old 10-01-2002, 10:07 PM
r.c.dealer's Avatar
r.c.dealer r.c.dealer is offline
deviant bit char-g pro
IR Bit Char-G!!!!
I was wondering if anybody knows if the IR BQC-100 IR PCB for the Bit char-g is compatible for use with the IR controller from the Smartland IR cars, or are they exclusively designed to only work with digi q controllers? I was wondering about this because they both have IR designations of ID. I would like to use this board rather then the smartland board becuase the board is a direct fit. The smarland pcb fits but I had to use hot glue to keep the board in place because the clear pcb cover won't fit.
I have converted a Bit Clone(bensu tbolt) by using the pcb from a smartland IR car and changing the charger port on the IR controller. Only problem was that the NiHm went bad. When I put a new battery in it I will post it.Worked great befor the battery crapped out on me!
Thread Tools
Display Modes
panther to bit char parts zakkstyle Bit Char-G / MicroSizers 1 06-25-2003 01:08 PM
bit char g!!!!! sengming Bit Char-G / MicroSizers 3 01-20-2003 04:36 PM
tallest bit char body? Sniper596 Bit Char-G / MicroSizers 2 11-23-2002 09:16 PM
UK bit char g life ......... boring Bit Char Bloke Bit Char-G / MicroSizers 10 11-10-2002 09:10 PM
bit char g - bit char g bike -bullet 00gt Bit Char-G / MicroSizers 1 10-26-2002 04:30 PM
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
