  #16
Old 07-25-2003, 11:45 PM
ph2t's Avatar
ph2t ph2t is offline
Chief Propeller Head
boho, there won't be any mosfets in the SBCG pcb, only regular transistors....
do you have a super bcg?
ph2t.
Old 07-26-2003, 07:23 AM
boho's Avatar
boho boho is offline
Camera springs
Yes, I have the red lambo and the porsche. Internal dual celling the lambo might be a bit of a pain, since the body is so low. I'm definately going to have to get down and dirty with the dremel for that. Any tips?
Also, I've never done a mosfet mod. Are there mosfets in the old bitcharge or are they transistors too? When I look at the diagrams, the mosfets look the same (little black rectangles) as the peices that you need to replace. I'm not a genious at electronics, so it sounds like I'm mistaking the two. Anyhow, the transister/mosfet looks the same in the supers. The pcb is set up either the same or similar, minus boosters and stuff. Are they the same? What am I looking at? Do you think the current is regulated to the same degree?
Thanx in advance to all my questions.
PLEASE help me: something wrong with the super bits transmitter ilovrc Bit Char-G / MicroSizers 2 02-27-2008 10:39 AM
The First and only bits with under glow STOCK! Comrade_Boris Bit Char-G / MicroSizers 13 01-07-2004 04:04 PM
Super Bits Impreza WR reX Bit Char-G / MicroSizers 1 12-29-2003 03:12 PM
The sticking motion in the super bits boho Bit Char-G / MicroSizers 0 07-20-2003 02:24 AM
Super Bit Char-G in stock. PseduoRooter Bit Char-G / MicroSizers 5 06-27-2003 10:54 PM
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
