-Skyline R34
-Fully propo throttle
-Fully propo steering
-Front suspension that mimics real car's suspension better
-Easily interchangeable spring suspension with diff stiffness
-Headlights that go on when in forward
-Brake lights that stay dim when cruising, full brightness when no throttle for 2 seconds or when in reverse
-Turn signals when you turn
-Motor connected to at least a 2 speed tranny, ball diff, and a couple of CV joints for actual rear independent suspension
-Redesigned chassis and pcb with re-positioned components so that it sits lower and gets closer to a 50/50 weight distribution
-A "turbo" function that engages a dc-dc converter to double the voltage to the motor....kinda like nitrous oxide cuz if u do it too much/too long it will destroy something
-Pneumatic tires
-A digital color vid cam that's very very tiny with 525 lines of vertical resolution and transmits at 30 fps to a receiver to get full motion full color hi-res driver's view
-A cell battery the same size and weight as the one used in Layman's Dual Cell Mod that provides 3.6 volts and has a capacity of 2000mAh and will take a very fast charge wihtout destroying itself
....gotta go, may update later with more wishes for the perfect dream bit.....yeh i know what i wish for is not possible or very expensive to implement but hey, who cars, its my DREAM car right? hehe, i like everyone's dream car idea here tho but i like mine better
