Old 11-28-2002, 08:34 PM
xatu's Avatar
xatu xatu is offline
they say im slooooow eh?
Probably, because ir doesn't do crap for my range...
Old 11-28-2002, 11:45 PM
caver01's Avatar
caver01 caver01 is offline
I don't think you will get much of anything by just wrapping a bit of copper around the existing antenna. The idea is to solder new copper wire to the circuit board, then coil the new wire in such a way as to improve range. Now, there are all sorts of ways to do this, but from what I can tell, the overall length of the antenna wire with respect to your transmission frequency has a lot to do with its ability to improve range. Also, there are some here that say coiling can have a cancellation effect. Finally, with respect to tight coils that may touch each other, it is important to recognize the difference between bare wire and wire that has an enamel coating. The coating allows wire to be wrapped tightly without conducting across the wraps. In other words, the enamel provides insulation. Enameled wire is used in the construction of electromagnets, such as those used in your car's steering assembly.
There are a lot of techniques to use here. For me, my idea was to internalize the antenna as best I could. For others, it's about getting better range. Some don't mind curly pigtails, while others like a bull-whip, extra-long antenna. The "best" often boils down to a combination of personal preference versus what you are trying to acheive with your mod.
Old 11-29-2002, 12:04 AM
DarthRacer's Avatar
DarthRacer DarthRacer is offline
Sith Bit Racer
Send a message via AIM to DarthRacer
Using 1/32 of a wavelength,
A 27MHz antenna should be about 1.1 feet.
A 49MHz antenna should be about 7.5 inches
- Calsonic
Old 11-29-2002, 07:27 AM
xXx_Vegito_xXx's Avatar
xXx_Vegito_xXx xXx_Vegito_xXx is offline
wuts with that lenth thing u said DarthRacer can u figgure out wut my 57MHz should be
Specs
custom paint
Honda s2000
3.0 motor (came as stock motor)
medium tires
Old 11-29-2002, 07:29 AM
my antenna
see me antenna is copper rite now and it like 2 cm shorter then the staock antenna but i get a 20 foot range there are pic on the 7th page of this thread
Specs
custom paint
Honda s2000
medium tires
Old 11-29-2002, 04:19 PM
xatu's Avatar
Yea, what about me? I got 35. And what makes the difference? It shouldn't matter!
Old 11-29-2002, 08:25 PM
Pojo's Avatar
Pojo Pojo is offline
Corolla Power!
you bit scientists confuse the hell outta me
Old 11-29-2002, 08:28 PM
xatu's Avatar
I'm with you, my head hurts!
Hey, this is cool, you gotta try this out. Put a long copper wire (a foot long) and stick it out of the back of your car like an antanna. Go in reverse, then go forward for a second. When you stop going forward, your front end of your car will bounce up and down looking like it has hydraulics
Old 11-29-2002, 10:57 PM
xatu's Avatar
I've never heard of this stuff, but if it works, that would be super cool! I would definitely go out adn buy some I would coat my car in it, lol.
Old 11-30-2002, 02:38 AM
caver01's Avatar
Actually, someone in this thread suggested that idea way back when I was talking about the copper foil. I don't think they ever tried it though. Might be worth a shot, but you would still have to setup a contact spring of some kind like I did on my car to connect the paint to the circuit board when you attach the body. Will it work? Who knows. I don't know enough about radio to know if metallic conductive paint has the same abilities as wire to capture a radio signal. Try it. That's probably the only way we will find out.
Old 12-01-2002, 05:30 PM
nissan2S nissan2S is offline
my antenna snapped on my bit char-g. the part where the antenna is held still squezzed through the rubber and then it snapped off over time. i only get a few inches without following it around. how can i fix it.
Old 12-01-2002, 07:02 PM
arch2b's Avatar
arch2b arch2b is offline
TinyRC & Mini-zRacer Fan
i'm not sure i understand where your describing the break?
Old 12-01-2002, 07:21 PM
baleisen baleisen is offline
Micro R/C'er in Da Burgh
Send a message via AIM to baleisen
Unsolder it from the board and solder another in its place. BAE
Smaller models, more control
Old 12-01-2002, 09:25 PM
AUDI-TT's Avatar
AUDI-TT AUDI-TT is offline
XMOD AUDI TT (my wish)
ALUMINUM
k i tried aluminum right. It works and u get pretty good range. But less than b4. And its actually quite easy to do. All u do is shorthen the exsisting antenna and take aluminum. Put the aluminum in ur car and put the wire in 2. COnnect them together by pinching some aluminum around the shortened stock antenna. But i have a quaestion. Is it the length of the antenna tha ,matters or the surface area???
Old 12-02-2002, 12:06 AM
caver01's Avatar
I think there is some science to this that would say that the length is what is important. As noted previously, the ideal antenna is one with an exact length that is proportional to the frequency, but as always, If you get acceptable results with aluminum foil, go for it! Nice to hear about that one.
need a new TX antenna? TypeZer0 XMODS Parts and Hop-Ups 3 02-15-2004 07:09 AM
Antenna Support System got BITS? Bit Char-G / MicroSizers 7 03-27-2003 11:25 AM
Alternate Soldering Ideas??????? tory_103 Bit Char-G Mods and Projects 4 12-23-2002 08:49 AM
TallgeeseIIII's Bit Char-G Ideas & Concepts TallgeeseIIII Bit Char-G Mods and Projects 8 12-13-2002 02:32 PM
ZipZaps: Antenna Mod pics available in Gallery Namuna Bit Char-G Mods and Projects 2 09-25-2002 11:13 AM
