Old 08-06-2003, 10:59 AM
Got 4.2 King? I do : )
i was drifting my black skyline today, i pulled a perfect 180 drift, it was nice.
hears my set up
shen chassie
shen pink motor (2.6-3.0 not sure)
soft blue up front
hard grey in back
orange gears
if you are having problums try this set up you should get your car to spin alot thats not exactly what you want but you want to harness that spin
first what you should do and what looks the best is lay down on the floor and drive the car toward you (i was using linoleum floor and it works good) now i hold the gas the whole time. start to turn the way you want to go and when you notice your car start to lose grip counter stear (turn the other way) now its all your release and timing has to be perfect. you need to let go before you start spinning the other way and after you stop the first spin.
if you can pull this manuver off you will be like damn that was pretty nice try it its fun
MY XMOD!
Yellow skyline
Springs: Hard all around
1.5 degree toe in
hard slicks
Top Speed stage 2 motor
full bearings
AWD
6 spoke wheel upgrade
energizer rechargeables
6 Cell Upgrade
Old 08-13-2003, 11:25 PM
Yugo DSC Maxxer's Avatar
Yugo DSC Maxxer Yugo DSC Maxxer is offline
Zip Zap SE Basher
Send a message via AIM to Yugo DSC Maxxer
My drift Setup:
Old Skyline body (Dropped)
3.0 Tomy Motor
Front Suspension Removed (Drop, again)
Stock Front tyres, and,
No Rear tyres
My Bit Char-G (Currently dead): and a Perfection 4.2....There really needs to be an icon for the 4.2's.
I got a Zip Zaps SE!!!
Yay!
Old 08-17-2003, 11:59 AM
ugh's Avatar
ugh ugh is offline
Holy Crap!
Send a message via AIM to ugh
Here's my setup:
MS PRO
Spring suspension (springs from rcmod)
Hard front tires
Soft rear tires
2.6 motor
9.86:1 gears
Toyota Sprinter Trueno SS version body
My method:
I start out by driving on hard wood floor unboosted. Then I press the boost button and the turn button at the same time, then immediatly let them go. This gets my AE86 into a nice drift that usually never needs counter-steer. I just press forward in unbosted mode until my Truneo gets out of the drift by itself.
With this setup, I can also do a sick reverse 180. I start in boosted reverse going straight, then I press either turn button (keeping boost on), and the Sprinter spins a nice 180, and I accelerate away in boosted mode.
I am very stupid when it comes to anything concerning tiny radio control cars, but at school it is a different story (I know none of you care what my life is like at school). Please do not criticize me for being idiotic and asking stupid questions that I should know. I have no skills when it comes to modding and driving Microsizers and other micro radio control cars. Please help me to raise my self-esteem. I don't handle criticizm well and when I do, I usually go cry into a pillow and scream and break things. In short, be nice to me (it may be hard though through all of my annoyance). Thanks pal!
Old 08-17-2003, 06:27 PM
Zip Zap SE Basher
Hmmm....
I need a booster! (Can you but those?)(I'm kinda like a newbie....)
Yay!
Old 09-19-2003, 09:45 PM
maxximum attack
I have finally drifted (fairly controlled on a track), and on normal unpainted plywood, I am still testing to find the right setup but I CAN tell you that :
Suspension: stock
Motor: Perfection 3.5
Tires: medium
Any hoo, here is a vid of me drifting in a part of my track.
Plzz ppl post vids and also tell me if this is how your drifts look. Mine looks great to me
Old 09-19-2003, 09:50 PM
that was a tight drift, i would try to post pics but i dont have a camera
it looks similar to when a drift but when i was drifting my shen motor it was a smaller radius, it was also on lynolium with hard tires in the back so thats probably why
also i bet that motor is just a bit to fast for that track
MY XMOD!
Yellow skyline
1.5 degree toe in
hard slicks
full bearings
AWD
6 Cell Upgrade
Old 09-20-2003, 02:23 PM
maxximum attack
I have done crazydave's antiboost mod so I can run a 4.2 on this track. I don't use my drift tires when racing tho. I cant drift through every corner and it spins out alot.
Old 09-23-2003, 10:41 PM
vtheo's Avatar
vtheo vtheo is offline
Monoaural.
Send a message via AIM to vtheo Send a message via Yahoo to vtheo
hmmm, i think the concept of drifting is a little different than the things you guys are talking about... but with my stock special ed. all i did was pull donuts on my floor. but with a gen2 pcb zz i could drift, just enough to make the turn much faster than letting of the throttle but with the new se's, it may not be as needed since you have more control over the speed, and wouldnt need to drift to slow down for tighter turns.
J-On
Old 09-24-2003, 12:08 AM
i was pulling great drifts with my shen motor and medium tires, i was triing my 4.2 pro with the mediums and its damn hard but i had it a few times
MY XMOD!
Yellow skyline
1.5 degree toe in
hard slicks
full bearings
AWD
6 Cell Upgrade
Old 09-29-2003, 09:34 PM
maxximum attack
here is a full compilation of my drifts
click here
Old 09-29-2003, 10:34 PM
fireball16789 fireball16789 is offline
My setup:
Ms Pro
blue gear
spring suspension
slick back tires(form tire set)
stock tires front
3.O motor
ferarri modena body
Old 10-17-2003, 03:55 AM
ownzorzor ownzorzor is offline
Easy-to-get-in-and-out-of-drift setup:
9.86:1
Bit Racer tires at the rear axle. Hard usually works best.
Hard suspension bar, to reduce turn radius.
2.2s are fast enough to drift.
With this I can drift on almost any smooth surface and regain control easily.
100%-drift-and-lose-control setup:
Drift axle!! :P
Hard suspension bar
1.0!!
This setup ownz!
Old 10-24-2003, 08:36 PM
geofroley's Avatar
geofroley geofroley is offline
R34 Skyline is God
Send a message via AIM to geofroley
Is there any mthods to drift with tires? I'm talknig like putting some sort of lube on the tires or something.
Old 10-24-2003, 08:59 PM
YES you can!
You don't need lube on the tires to drift! Most of the time it's your tires and motor that are responsible for drifting. As long as your car cannot maintain its grip on the surface you can drift easily.
Old 10-25-2003, 08:07 AM
geofroley's Avatar
R34 Skyline is God
Well I'm using stock slicks and stock motor(But an RCMod Phast motor and NiMh cell is in the mail).
Drifting explained steelo Miscellaneous Discussion 5 07-14-2007 07:35 AM
DRIFTERS ... anyone ever seen a Hirobo DRICON kylelucas Other Tiny RCs 5 10-06-2004 08:29 AM
attention XMODS drifters Daazndood XMODS 29 11-27-2003 06:27 PM
Boosters are good drifters! Zephyranthes Bit Char-G / MicroSizers 2 04-02-2003 12:56 AM
