Old 01-15-2003, 12:43 PM
323iT's Avatar
323iT 323iT is offline
Send a message via AIM to 323iT
anyone try hitting the boost during the turn? it helps in getting the rear loose
Old 01-17-2003, 07:33 AM
Racer9's Avatar
Racer9 Racer9 is offline
Tiny RC Pro
I drift with this setup.
As in custom tires I mean no tires!
Old 01-17-2003, 07:14 PM
AzNRocket's Avatar
AzNRocket AzNRocket is offline
AzN InvAzN
i tried doing the boosting during a turn it helps, but sometimes i just spin out.
Celica :
Auto Modellista Set:
OtheR RyDes:
Bensu Bullet Mercedes
Bensu Bullet fOcUs
Old 01-18-2003, 02:52 AM
323iT's Avatar
yeah Bit Char-gs are not as consistent as 1/10 4wd cars. These tiny rcs are harder to drift cuz of the lack of differenctials and none proportional steering.
Old 01-19-2003, 01:29 AM
met-sb
cool
it would be realy cool to just take the tires off like i did and just us it cuz theres no grip so u can slide all over the fricckin place
its realy fun like that
Old 01-19-2003, 02:17 AM
Fourustwentius's Avatar
Fourustwentius Fourustwentius is offline
Help Me!
True dat! I took em all off and just went buck wild! Victory circles! Throw in some baby powder, or graphite lube,that stuff is awesome!
At the bottom.
Old 01-20-2003, 03:29 PM
Maza's Avatar
Maza Maza is offline
Go
lol,mine are 2.2 moter drift gears no rear tires its so fun it will do a little wheel spin just in the middle of the track
________
DRUG TESTING KIT
________
DEPAKOTE SIDE EFFECT
________
LIVE SEX WEBSHOWS
Old 01-21-2003, 11:23 PM
BOme}{_2k5 BOme}{_2k5 is offline
Send a message via AIM to BOme}{_2k5
lol its amazing how much you can do with an import tuner car.. i made a rear axle with the wheels and the tires and it works so perfect for drifting! when you're drifting around you don't spin around much en yea.. haha well das it
Old 01-22-2003, 08:18 AM
BenCloned's Avatar
BenCloned BenCloned is offline
Clones Are Good
Originally posted by cowfish_29
front tires: bit racer hard
back tires: bit racer soft (medium on TheFanMan's track)
softest stablizer bar
blue acceleration gearing
bensu 3.0
Hey cowfish,
What color is the cap on your Bensu 3.0?
My Bensu motor is white, and fast as he!!, but with the right gearing, my 2.2 can nearly keep up.
Also, I get 25 - 30 ft range with my Bensu.
Drift setup:
Bensu motor
Medium front tires
Hard back tires
Soft stabius
7:1 Gears (8 tooth Bensu pinion with 9.6:1 axle/spur)
It just spins donuts with the body, but without the body I can sometimes get it to powerslide on the dining room table.
Shen Qi Wei:
Begun this clone war has.
- Yoda
Old 01-22-2003, 07:56 PM
strakka's Avatar
strakka strakka is offline
AA member
Send a message via ICQ to strakka Send a message via AIM to strakka Send a message via Yahoo to strakka
a great mod for drifting is to do front wheel drive and rear wheel stearing. just reverse the body of the car. you also have to reverse every thing on the pcb. so just swich forwards and with backwards and left with rite. it looks kool. i did it to my car. remeber to reverse the car when charging
Old 01-22-2003, 08:06 PM
BenCloned's Avatar
Clones Are Good
Kind of like a Forklift. Interesting...
Shen Qi Wei:
- Yoda
Old 01-22-2003, 11:24 PM
cowfish_29's Avatar
yellow fish forever!
Originally posted by BenCloned
Hey cowfish,
Drift setup:
Bensu motor
Medium front tires
Hard back tires
Soft stabius
my cap is yellow and looks just like a 2.2 but it ran like faster than my 3.0 and had 4x the acceleration it seemed like. But now its dead, cant decide why. one day it up and quit going fast. It might have something to do with my rally track.
my bensu got 2" of range, and you cant drive with the antenna touching the other antenna the whole time. I just use mine for parts now.
the reason you are donuting is cuz you need softer tires on the back to make your back not slide out TOO much. just enough. Its tricky, so try some different combos with stabiuses and motors (i find that 2.6 tomys are good for hardwood) and just try it out.
Old 01-23-2003, 07:59 AM
BenCloned's Avatar
Clones Are Good
My Bensu motor does have tons of acceleration. I use it for drag racing, mostly.
If I use furnature polish on the dining room table, I can drift perfectly with this setup:
Just like the big boys!
Shen Qi Wei:
- Yoda
Old 01-24-2003, 02:18 AM
met-sb
the best drifting so cheap and fun
y dont u just take tires off all wheels and go all over the place its realy fun or if u dont feel like buying drift gear than just take back tires off simple as that
Old 01-24-2003, 08:42 AM
BenCloned's Avatar
Clones Are Good
Most of us still want control over the car. It's a racing technique.
Shen Qi Wei:
- Yoda
Drifting explained steelo Miscellaneous Discussion 5 07-14-2007 07:35 AM
DRIFTERS ... anyone ever seen a Hirobo DRICON kylelucas Other Tiny RCs 5 10-06-2004 08:29 AM
attention XMODS drifters Daazndood XMODS 29 11-27-2003 06:27 PM
Boosters are good drifters! Zephyranthes Bit Char-G / MicroSizers 2 04-02-2003 12:56 AM
