10-25-2006, 10:21 PM
Thanks for the nice comments!!
I would say your set-up is pretty good as-is with the 33/6 and if you notice the trails are too hard to traverse you can then try the swap. If you have a SSMT you have the board already!
I posted a little vid of the Hummer at the link below. I'll try to make a better one soon!
http://video.google.com/videoplay?do...977&pr=goog-sl
10-25-2006, 10:26 PM
are you talking about a ssmt 1:24 or the "oh so famous" 1/43 ssmt??? which by the way i am dying to get.......
i am asking you this because i have an ssmt 1/24, and i want to swap the electronics for a new iwaver PCB, so it could be proportional.
annyways, sweet hummer, and keep the modifications coming, i like your ideas. i have been thinking of a tie rod design to eliminate the bump steer, but i will use one steering rob for each knuckle.
-Lino
11-24-2006, 02:29 PM
On your steering mod diagram, there is three screws...one in tie rod...one in lower a-arm into bottom of hub...and don't know where the other goes. Connect custom plastic piece to modded tie rod and where do you connect custom piece on the hub???
Nevermind figured it out.........sorry
Keep forgetting that tie rod in modded
03-22-2008, 02:17 AM
Yeah, I like to nkow the details too. its too bad the swampers are hard plastic, guess u must spin out on TILE FLOORS
Eric
03-22-2008, 02:30 AM
Originally Posted by ZipZapin
So you basically put a spacer in front of the bearings?
I have loads of teflon washers, that should work too?
Well does it, Im new the EVO Trucks, and just got a TITAN but the wheel slop is nasty...I want to get bearings but dont know if that will fix the sloppiness in the 4 wheels.
Any got time to elaborate ways of cure this EVO-truck disease..of mine?
ERIC
03-22-2008, 11:01 PM
You want "wide track bearings"
I haven't ordered from this guy yet, but he has good dealings with a lot of folk at Scale4x4Rc..... and they say he is fast to ship also, even though it's overseas.
Click me.
