Old 12-25-2004, 12:19 AM
I have a beach ball...
Man, if you want a mini-z, go get a damn mini-z and leave us alone. You're borderline trolling here.
'65 Ford Mustang
All the RS goodies
Becoming a donor car for:
'04 Ford Mustang Cobra
Old 12-25-2004, 10:04 AM
viperdout's Avatar
It's Really Fast!
Originally posted by xxxmod
ha ha that would never happen.how about this i'll get my friends mini z the thing it has is stacked fets and a turbo motor you get a xmod with the same stufff and the mini z will take it and the mini z is like 5 years old it's not even the new version cause my x mod is hooked and the mini z still takes me so like i said im right and your wrong merry x mas
For the last time, it's gear ratios, not number of gears. I also also see that you're too much of a wuss to say where you're from in Jersey. Would your friend like to be schooled by a brushless xmod?
Project Bad Brushless:
Just say no to giant sigs.
Old 12-25-2004, 05:20 PM
xxxmod xxxmod is offline
viperdout im from paterson for 32 years just moved to prospect park. This the last thing im going to say first if you looked what i said i don't want a mini z 2 if i put a brushles in a z what do u think will happen the thing im saying is the xmod has to many gears. This is my world and in my world the xmod will always be slower it sucks to say cause i like them thats why i have one. will never beat a mini z
Old 12-26-2004, 10:54 AM
viperdout's Avatar
It's Really Fast!
viperdout im from paterson for 32 years just moved to prospect park.......... in my world the xmod will always be slower it sucks to say cause i like them thats why i have one. will never beat a mini z
Well, if I have a pinion with 28 teeth that touches another 28 tooth (all same diameter) which then touches the last gear on an axle with the same diameter and 28 teeth, I have a 1:1 ratio. If I now have a 14 tooth pinion that directly connects directly to the 28 tooth pinion on the axle, I have a 2:1 ratio, which would provide more acceleration, but not nearly as much speed.
I don't think you understand how hard it is to drop in a brushless motor, let alone what it is! Hell, I've got one and I'm still foggy on it. The Z has next to no room to fit a brushless motor, let alone a spot to place li-pos. If a Z had the same amount of room, I would've used it, but it doesn't. It has no room for everything. Brickmodder did a very smart thing, and had someone design a circuit that reads the xmod's signals, then sends it to the Mamba ESC. I'm doing it differently. I've shoved all-new electronics into this thing, and just have to machine the gear and I'm done (I'm going to do that today or tomorrow). Do a search on xmodworld and xmodrc for the 2nd Brushless xmod, and on xmodrc for the Black Mamba (Brick's car).
I'm in Oradell, about 2 miles away from Paramus.
Old 12-26-2004, 11:21 AM
what ever
Old 12-26-2004, 12:11 PM
viperdout's Avatar
It's Really Fast!
what ever
You misspell a word, that's fine, everyone makes mistakes.
Old 12-26-2004, 12:29 PM
this went to far
Old 12-26-2004, 08:34 PM
viperdout's Avatar
It's Really Fast!
this went to far
I ............merely goaded you to race me if you want to prove your point. That is not illegal by any sense (unless your xmod can get a ticket for breaking the speed limit). I love Zs. I'm looking into buying an MR02 right now. If I get it, I'll be dropping in 2 lithiums, a Nelly 1.3, and an S04. The Mini-Z is a great vehicle, but right now, my xmod can beat every one of them in the US. It is no offense to any Z person, as I have dumped a good chunk of change into this thing. Again, a Z has a has a higher-speed ratio, and it has nothing to do with number of gears. If I mounted my bevel on my motor, I'd actually go slower because my current gear ratio is 1.09:1 pinion to bevel.
Old 01-03-2005, 07:09 PM
Zero-Man
xxxmod + viperdout
Your posts have been edited and I am graciously asking you 2 to keep it civil without name calling and finger pointing.
Thank you in advance for your cooperation.
Zero-man, new mod for the XMod forums.
Old 01-03-2005, 07:55 PM
viperdout's Avatar
It's Really Fast!
Originally posted by Zero-Man
xxxmod + viperdout
I would like it if you would at least spell correctly in my posts.
Old 01-03-2005, 08:11 PM
Zero-Man
Sorry, I guess we all make mistakes...
Old 01-03-2005, 08:15 PM
viperdout's Avatar
It's Really Fast!
Yep.
Old 01-04-2005, 11:36 AM
baleisen baleisen is offline
Micro R/C'er in Da Burgh
Send a message via AIM to baleisen
I wish that somebody would do alloy parts that fit together with whatever other alloy parts are on the market.
Smaller models, more control
Old 01-04-2005, 12:04 PM
Horshu Horshu is offline
Obsessive Modder
baleisen: Here's a kicker -> The GPM front suspension arm doesn't even fit with the GPM front deck! The front deck's forward-most screw holes extend the deck out just like with the stock one, but the alloy suspension arms are too thick to clear them. I had to use a dremel to shave the screw holes flat with the rest of the plate.
Old 01-04-2005, 03:25 PM
viperdout's Avatar
It's Really Fast!
No suspension arms fit unless you mod the GPM front deck from what I remember. GPM did a terrible job on design. The dogbones are way too tight on the RSX rims, and I have no other parts to compare, except for the lugs, which are 3mm, so the xmod driver doesn't work.
Xmods with 2 body, V2, GPM PARTS & more stormwolf18 For Sale/Trade 1 04-28-2005 04:44 PM
GPM parts for Xmods! T Man XMODS Parts and Hop-Ups 34 08-06-2004 10:04 PM
gpm xmods parts with pics smratperson XMODS 6 08-05-2004 03:14 PM
Xmods Announcement cj1267 XMODS 2 10-16-2003 04:34 PM
