Old 03-20-2004, 06:53 PM
Zero-Man
The Spy makes the X-FRAME run like a bat out of .........I guess the M-bb helps a little. Spun the tires off in the corners and NEVER flipped the beast. Laid flat batteries!
Old 03-20-2004, 06:54 PM
Zero-Man
Top view
Old 03-20-2004, 06:56 PM
Zero-Man
Tomorrow I'll have the time to add an AWD, Bearings and shock upgrade. Now if only somebody would come up with some better diffs...................
BTW, the rear battery plate hold down was modified so that I can use Model Power Peugeot 206 shells. That will really be nice tomorrow with the AWD kit installed. A rally 4WD racer!!!!!!!
Mini-z'rs have dreamed of that for a while
Old 03-20-2004, 08:13 PM
SolidSnake899 SolidSnake899 is offline
Hello! Man that is sweet! But just what exactly is that spy thinger?
Old 03-20-2004, 09:26 PM
Zero-Man
Novak Micro Electronic Speed Control with F-B-R, made especially for micro's and can be used on most mini's. Like putting a Turbocharger in, it pumps juice like only a real ESC can. But it cost's more than the X itself. If you wanna play you gotta pay.....
Old 03-20-2004, 09:48 PM
Zero-Man
The first 3 mod upgrade kits in the shop have an 00-80 screw included so that you can make the drive nub for the stock tie rod. This works with the HS-55 servo and the long narrow double ended plate, use the hole that is the furthest out from the center, trim the opposite end flush with the center hub. Thread the screw gently into the hole and secure with a drop of CA. place a little heat shrink over the screw and test the fit. Trim the screw length until it clears the right suspension mount.
The speed and control of the HS-55 is truly race worthy. the throw is so long that you must trim back the EPA and adjust the dual rate down, otherwise the tie rod will come out of the servo plate! This translates into faster steering and very tight steering radiuses. Can't wait to try it on the AWD tomorrow. This should make the Mini-Zer's more than just a little, dare I even say it, scared. I love my Mini-Z's, but an AWD that the rally Z shells fit? That is really what we wanted all along. Time will tell.
New pics up with the SPY esc fit on the mod chassis.
PDF Instructions/Drawing up at the site as well as the Excel files.
Old 03-20-2004, 09:49 PM
meteoraclown meteoraclown is offline
hey zero, do you have any pics of a rolling CF chassis? i want to see how it get's held together.
Old 03-20-2004, 09:53 PM
Zero-Man
Did you check out the beginning of this thread? or;Development thread page 8
Old 03-21-2004, 11:05 AM
Will somebody please help me I cannot access the directions on how to put the chassis on my XMODS! I do not have Excel so it won't let me view the page, would soembody please get into the page, and e-mail it to me at SolidSnake899@yahoo.com. PLEASE!!!!!?????? thanks in advance
Old 03-21-2004, 03:20 PM
Zero-Man
PDF files are now available at ZERO-PPRODUCTS.COM It's under the news release for the chassis, front page. Or here:
Instructions
Drawing
The file clarity leaves a lot to be desired, but it is readable
Old 03-21-2004, 03:57 PM
Zero-Man
AWD kit an component pics
Old 03-21-2004, 03:58 PM
Zero-Man
HS-55 servo mounted on top plate/servo plate
Old 03-21-2004, 03:59 PM
Zero-Man
RCVR, Spy ESC, motor retainer plate, all mounted on the battery plate
Old 03-21-2004, 04:00 PM
Zero-Man
Assembled Battery Pack
Old 03-21-2004, 04:06 PM
Zero-Man
Had a ball this afternoon running the Peugeot 206 Rally with MZR M-BB motor-8 tooth, AWD, bearings, suspension kit, SPY ESC, HS-55 servo, Laid flat battery pack, and of course, the X-FRAME PRO MOD chassis.
4WD drifts on concrete!! Stable and fast. The 206 ran better than it ever did on a Mini-Z chassis. If it's posted here then you know why
Micro-T Carbon Fiber Chassis DAMZer Micro-T Parts and Hop-Ups 14 05-20-2010 06:57 AM
Carbon Fiber Chassis & Decks By XMODSource Are Finally Here! xodus XMODS 8 11-21-2004 07:08 AM
Carbon Fiber Chassis WillS Mini-X 22 08-13-2003 07:17 PM
