Old 10-23-2002, 08:52 PM
Mike410 Mike410 is offline
Thumbs up it worked
yay! i just did the mod i definately notice a difference and it has no reverse so i think it worked.
Old 01-01-2003, 06:03 PM
scottyboyfun's Avatar
scottyboyfun scottyboyfun is offline
Im a cat, miow.
Send a message via Yahoo to scottyboyfun
Heres my MOD of the speed boost mod.
Rather than loose the reverse, I have placed wires with Diodes allowing electric to pass in only 1 direction,so no shorts!
What do u think?
All ive done is-
The original mod involved removing a wire from the pcb, and putting it straight to the cell.
Ive replaced the wire,put a diode on it(to allow 1 direction electric)
and attached another wire to the motor, with a diode, going to the - side of the cell, what do u think?
I havent tried it yet,but theres the theory!
So what do u lot think?
Post it!
Old 01-01-2003, 06:05 PM
Im a cat, miow.
Here is the original mod diagram so u can all compare n work out what ive done!
Post it!
Old 01-13-2003, 01:53 AM
RaMMeR
Awesome idea here! too bad that it didnt work for me. Followed your directions to the T and all I had was reverse, no speed increase, nothing. Since I had opposite results, i started by using the other wire, this time had nothing at all. Hmmm one may say..well must be this darned Z-Cars PCB that hates me. Would have loved to enjoy extra speed!
I have a dual-cell NiMH mod in this btw.
PS: This is the original no-reverse mod, not the w/diode.
Old 01-13-2003, 11:41 AM
Im a cat, miow.
I don't know if the diode version will work, but in theory it should!
Post it!
Old 01-13-2003, 05:59 PM
fastbs
my zip has dual cells & the pcb is modified. I just did the plan no reverse mod and it helped greatly and i don't miss reverse much at all. i'm still wanting to go faster i'm thinking about the 3.8 rspec motor
Old 01-13-2003, 06:00 PM
fastbs
i forgot to say i'm running the NOS motor currently
Old 01-13-2003, 06:30 PM
Nathan's Avatar
Nathan Nathan is offline
Bad Driver
I did th REAL PCB mod, where you remove four resistors. It made a little difference. then I did a two-cell and now my ZipZap is comparable to my Z.
Old 01-13-2003, 07:05 PM
fastbs
the no reverse and removing and jumping some of the resistors makes it even faster
Old 01-14-2003, 02:27 AM
RaMMeR
which resistors are we referring to? and are there pics?
Old 01-14-2003, 09:28 AM
fastbs
i completely removed r17 & 18, and jumped (put a glob of solder on top of to bypass) r20 & 21 which are on the under side corner of the pcb and the same with r16 & 19 on top of the pcb some say to leave 16 & 19 but every thing worked for me. after i did this the car will go on carpet.
Old 01-14-2003, 09:33 AM
fastbs
pics of the 16 & 19 are on mattydiahs zipfaq shown earlier in this forum just click where it says "check out the zipfaq" on his posts there is somewhere else but i cannot remember where
Old 01-14-2003, 06:09 PM
Nathan's Avatar
Bad Driver
I only removed the resistors for forward, so i have a slow reverse to back out when my car gets stuck.
Old 01-15-2003, 01:46 PM
Im a cat, miow.
Is the zip zap pcb much different from the panther (tomy clones) ?
Post it!
Old 03-26-2003, 04:34 PM
Labmonkey's Avatar
Labmonkey Labmonkey is offline
Tortured Primate
nice
finally got a chance to try this mod....definitely a boost in power. my old Mustang never moved so fast. It was dead even at the start with my Xmen Mazda (which has always been much faster even with the same motor/gear combo) then pulled ahead after about 2 feet. If only my 27Mhz Xmen had better range
Still looking for a good way to fix that problem.
Imagination is more important than knowledge...
Albert Einstein
New Zz Pcb Mod gpile ZipZaps 85 11-04-2004 11:25 AM
Another PCB mod and Schematic Dayfall Bit Science 42 03-25-2003 12:19 PM
Need to Flip PCB for a dual B mod? ejaf ZipZaps 6 11-24-2002 10:15 PM
PCB Mod and Dual Battery Mod are both safe? tylude ZipZaps 5 10-26-2002 04:11 PM
Dual/Triple Batteries and PCB Mod SuavePowerBaby ZipZaps 5 10-21-2002 07:45 PM
