Old 02-26-2004, 12:40 AM
codedat
I think you may have applied too much heat to the inductor. Did you use heat sink clips before you heated up the solder?............ If not then that's why it goes only ten instead of 20 to 30 feet like it should.
Old 02-26-2004, 10:39 AM
Racer240's Avatar
Racer240 Racer240 is offline
No I didn't use heat sink clips and I've never heard of them before Is this what they are? Was I supposed to just clip it on to the L2 inductor so it would "cool off"?
Racer240/2zer0's R/C Gallery
Old 02-26-2004, 02:10 PM
charliebrown's Avatar
*sigh* Here's a real simple solution. Just wrap some foil around your antenna, the more you wrap around it, the more range you get.
Chuckster...
Old 02-26-2004, 07:25 PM
codedat
Yes, those are one in many types of clips. You clip it on the end that you are going to solder ON/Off to reduce heat going to componet.
That's ok but if you are in to looks you might want to use a cellphone antenna.
Old 02-27-2004, 08:45 PM
.....Well, there's always that.
Chuckster...
Old 02-28-2004, 07:05 PM
aperson's Avatar
aperson aperson is offline
I'm not a pyro, really.
i tried to switch one of the other ones from the little PCB to the antenna today but the range still sucks. i never used the heatsink clips. could that be a problem?
NEVER UNDERESTIMATE THE POWER
Old 02-28-2004, 07:11 PM
newbitowner's Avatar
newbitowner newbitowner is offline
^ by my new PCB ASSY.
I have 2 new PCB's for sale.
G35 rolling chassis
H2 rolling chassis
Cobra,rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
Old 03-03-2004, 06:53 AM
codedat
To get back on the subject I bought some more inductors from digikey and found that there is a small, vary vary small difference with changing the 0.42uH inductor to a 0.47uH. If you have a bigger cap on the Main PCB it will cause slight interference to the stearing servo. Not enough to make you mad, only for a micro second. Also the good news, these inductors are higher rated so they will not burn up as easy as the stock ones.
Old 05-11-2004, 11:41 AM
baleisen baleisen is offline
Micro R/C'er in Da Burgh
Send a message via AIM to baleisen
How do you use a cell phone antenna?
Also, I drilled the plastic case so I could adjust the can.
20 to 30 FEET?? No wonder people are going to real 'tronics with the carbon fibre chassis.
BAE
Smaller models, more control
Old 09-27-2004, 09:32 AM
XmodDad XmodDad is offline
The two resistors are #1 222 ohm and a 4.7k ohm. You can use 1/4 resistors with 10% or less tolerance. I have replaced mine and my daughter's car and they run great. The only tricky part is mounting them in because they are a tad bit bigger than the stock ones.
Hope this helps.
Old 09-27-2004, 09:36 AM
Once you change out the resistors, you will need to re dial in the reciever range. Its that white circle thingie with the wax in the top. Remove the wax and have a buddy hold your controller and squeeze the throttle. While walking backwards. Once the motor stops, adjust the set screw until the motor starts again. Have your buddy start walking backwards again and repeat. Once you get the range where you want it, light a birthday candle and fill the slot up with wax again.
Old 10-06-2004, 03:49 PM
mod_o_matic mod_o_matic is offline
has any1 tried to change the attena on the car with some Cat-5 Cable? It helps in the smaller cars like ZZ or big char gs..why not Xmods???!
Old 10-08-2004, 11:16 AM
ninja828 ninja828 is offline
i know there are some people out there that've used cat5 for antennas and they've said that they gotten a 10ft increase in range or so
smart range question rydzjunior XMODS Mods and Projects 0 03-03-2007 07:39 PM
ZZMT Remote Range 88-Fiero-GT ZipZaps Mods and Projects 1 10-09-2005 09:03 PM
Poor range kennylxix XMODS 7 12-22-2004 02:13 PM
My extended range mod ;x soggyrice.mMmMm Bit Char-G / MicroSizers 7 04-22-2003 11:13 PM
range of 27 MHz versus 49 MHz gRC ZipZaps 12 09-30-2002 06:33 PM
