the knuckles on my 1/32 bruiser uses a thick brass tubes, because i plan to use this truck through mud, those tamiya three speed gears are too big to work on, one reason why i ditch it off the truck and it's way too fast, well that's just my own opinion, i meant the gear ratio is so high that you could burn your esc easily or if your electronics could handle it.. your battery will run out of juice pretty quick!, just look at how close the size of the tamiya mini-4wd tires are compare to the main drive gear!.. gears are like tiny levers.., build your gear combinitions so you could maximize the space you need for your electronics.
hehehe
