11-21-2003, 02:56 AM
Overworked
Timbo,
Get a roll of tin tape at a hardware store. It is the kind used for HVAC ductwork and is made out of aluminum with a sticky back.
Cut off a very small peice and wrap it around the shaft until it is the right diameter. It works great and can be used on a hundred different modeling tasks.
_______________
I just like to build.
Micro RC for way over a decade
11-21-2003, 05:38 PM
Thanks for the help, but I found a solution. I had some old bit tires, so I cut off a small piece of that rubber, and just press fit the gear over the shaft and the rubber. It holds reallly well, and if it doesn't work while actually running the truck, I'll try that tape method.
-Tim
mtb=beast
11-22-2003, 11:14 AM
Confirmed: Lost In Fog
Originally posted by squeegee
I know this is EXTREMELY off of this forum's topic but............ have you ever considered building some R/C planes? I know your work on planes would be amazing. I have a Firebird, a Firebird XL, and a five foot wingspan electric trainer.........I also have put 723 hours into my Real Flight simulator.
I am working on a line of micro planes from cheap R/C tanks and rubberband powered planes. They have reeeaaaallllyyyyy simple steering.........just like a tank........no need for a rudder.
please see my posts in the micro flight section!!!!!! i fly!!!!!!! (and also look in the bit char-g gallery to see my layout, the post is titled "action shots of my WRX and bB")
-Andres
01-21-2004, 08:36 PM
Location: The land of all things faster than they need to be.
Where did you get the gears/gearbox? I intend to use a GWS IPS gearbox to use with my IPS gear, and I already have a servo. An IPS-F should work nicely, and if that will not function, I could always get a
EPS-100. I fly micro RC and I have a CS-6, and it puts out 13 0z of torque.
Ninja Burger: Your burger in 30 minutes or less, or we commit seppuku!
01-21-2004, 11:19 PM
Overworked
Cheesehead,
The GWS gearbox you are talking about is bigger than my whole truck.
My gears come from HO scale train stores.
_______________
01-23-2004, 12:19 PM
I guess I never really had an idea of how small these things really are.
Does anyone think the IPS motor would work? They're pretty small, and have a small profile.
01-23-2004, 01:17 PM
Overworked
Does anyone think the IPS motor would work? [/b]
NO!
If you are following the spirit of the Euopean style TTTT, the vehicals must be 1/87 scale. An IPSs motor is bigger than the truck itself.
However, there are guys building small rock crawlers that are not true TTTT scale. Look at Killers 1/35th scale rock crawler. Your IPS motor could work on big trucks like his.
I prefer the challenge of 1/87th scale. Build one of these, and you can build anything.
_______________
01-23-2004, 03:13 PM
Geez..I never had a clue of how small these things were.  Stupid me
I'll go with your advice on this one. What kind of motor do you use? I already have a dinky servo (CS-6.2) and rx (GWS pico), and a 2 amp ESC, with some 7.2 LiPo and LiIon packs.
Does anyone know where I can get HO train gears? I'm no engineer, and want to just have something that works. I have some ho trains, just none that are available for demotlition.
01-23-2004, 07:36 PM
Overworked
All I can suggest is that you read alot and try browsing the web now and then.
A good place to start would be to read this thread from the begining.
-Todd
_______________
02-25-2004, 06:07 PM
im going to get started on a ttt soon, its going to be work thoe,
im not conserd about the money, but it looks pricy,
im just going to use it as a spare time project, since i have alot of that....
it will also look awsome for my digi-q tank track,
has anyone ever tried doing a infer red laser systems like in a digiq tank??? that be cool
bits,1/10,TTT,1/18
02-25-2004, 06:15 PM
if you go here its a tread on how to make ir electronics. and unless you know alot of electronic stuff (unlike me) its really good.
