05-18-2003, 02:04 AM
Proud to be Pinoy :)
another shot.
hehehe
05-18-2003, 06:00 AM
articulation!
hehehe
05-18-2003, 06:03 AM
home made peak charger...
modified cellphone charger... red when charging.. and turns green when full charge!
hehehe
05-18-2003, 06:04 AM
internal..
hehehe
05-18-2003, 06:06 AM
bulb discharger
Ni-Cad batteries should be discharge to the minimum level before charging  ...
hehehe
05-18-2003, 11:07 AM
TinyRC & Mini-zRacer Fan
as usual, absolutely remarkable work  i'm going to get the parts for the cps this week and do the mod...i hope to have somethingto post for you by next weekend
05-18-2003, 08:15 PM
thanks Arch! hope to see pics of your project too.
hehehe
05-18-2003, 08:20 PM
Overworked
Killer,
OUTSTANDING!!!
The creativity just flows off of you man!!
_______________
I just like to build.
Micro RC for way over a decade
05-18-2003, 08:34 PM
Originally posted by Overlander
Killer,
OUTSTANDING!!!
:ö: shucks... thanks overlander.. ei!, any update on your projects? -æ
hehehe
05-18-2003, 08:56 PM
i think you may have done this already, but could you start a thread in the other section on how to make that very cool cell phone charger! that thing is cool! we all have old cell phone chargers too...atleast i have about 4 of them
05-20-2003, 03:28 AM
hehehe
05-20-2003, 04:25 AM
:ö:
The unit i'm using here is a Philips Savvy Switching Adoptor, that produces 4.5-9 volts with 550mAh of power, the reason i used this unit is because it has a built-in led indicator, red when charging.. green if full, now the green rectangular circuit board (on the pictures "internal" ) that came from a Li-ion cellphone battery, which i understand that this will allow a standard cellphone charger (usually used to charge ni-cad or Ni-mH batteries) to charge a Li-ion battery! which we all know that requires a special charger for us to be able to charge it, now i attached that circuit board to the 6.+ (i have to double check the exact voltage output) output of the charger, my first intention here was to make a cheap Li-ion battery peak charger, it was a success  i was able to peak charge my Li-ion batteries to be used on my new 1/32 project truck.., then i tried to test charge my TTTT Ni-Cad batteries and it works, gives me the same run time using my 1/10 scale peak charger, then i test charge a 100mah Ni-Mh batteries and as expected.. full charge! though it takes abit longer for the led to turn green (batt full) because the Ni-mH batts have higher milliamps compared to the Ni-Cad one that only have 50mah, which requires shorter time to full charge, remember the "battery charge calculator" thread?.. this will help you a lot to understand how long your battery to charge depending how may amps your battery is compared to the output of your charger.
arch,
i'll try to shoot some more pics of the charger i made,.. then i 'll test a Nokia charger too using the same procedure, if the outcome is the same, i'll let you all know about the result.
-æ
hehehe
05-22-2003, 02:18 AM
charger back view..
hehehe
05-22-2003, 02:19 AM
back view of the small circuit board..
hehehe
05-22-2003, 02:21 AM
almost complete.. my 1/32 TXT-1 inspired 4WD Monster Truck
hehehe
