03-27-2003, 03:04 PM
BIT PIMP
Originally posted by denden
OK , it's only a 18 window but , it is a mini ??
That looks great dude... When can I buy it? That's gonna look good next to spankys truck...  Let me know
silla
03-30-2003, 04:03 AM
Mr. Goop
ok. i just did the wheel mod and now the car is looking awesome. i will follow up with a how to, on the wheel mod, tomorow or the next day. i have to sort through all of the pics that i took... i also need to extend the charging base on my controller so that i can get the car to the charger. ride height has been almost trippled..
03-30-2003, 04:04 AM
Mr. Goop
heres one pic
03-30-2003, 04:17 AM
Mr. Goop
woah!! first test run and this thing flys!! gets good grip, and high top speed probably due to larger tires.. only problem is steering. i need stronger magnets, and a stronger steering spring.
03-30-2003, 11:18 AM
midgetPimp
looks great
I have that super glue you see in that pic: IT SUX!
03-30-2003, 01:16 PM
Mr. Goop
humm its working great for me... although i prefer Maxi-cure extra thick glue..
03-30-2003, 01:20 PM
midgetPimp
It holds good, its just too liquidy, and takes a super long time to dry
03-30-2003, 01:59 PM
Mr. Goop
humm must be something with the air. mine is liquidy, which is what i like about it. but mine drys instantly.. if you want to speed up drying. get some insta-set spray. they should have it at your local hobby store. if not tower hobbys has it.. i originally got it for my maxi-cure which is thicker and can fill gaps and stuff. once sprayed it the cure time is about 2-3 seconds.
04-11-2003, 07:03 PM
It's Really Fast!
Spanky, the PT crewzer in the background of one of your pics! Where are those springs available?! They might be cool for my dual motor car!
04-12-2003, 12:09 AM
Mr. Goop
they are to big for bits. your best bet for springs is to check out slot car springs.. there are several sizes. and they are not magnetic...
04-28-2003, 12:24 AM
Mr. Goop
progress report:
part 1:
initial bodys were desigend for the raised chasis. and would still work great for a lifted bit. however the sides of the truck are to narrow to slide over the chassis...
part 2:
i chopped one of the resin bodys down the middle to make it wider so it would drop down on the chassis. everything was fitting perfect.. till i tried to mount on the tabs. the body is somehow magicly shorteded by 2mm... so the body will slide down to the mounting tabs now...
part 3:
Hammer Time!!! you guessed it, frustration set in with that resin body. so ive just poured another body and i now know what mods need to be made befor the next cast is made. slightly wideer and slightly longer...
thoughts:
i just hope i auctually get this finished befor tomy comes out with one... lol however my zip zap woody is coming along great. external detail is about 98% finished. mounting tabs are also about 85% finished. i think i am going to smooth out the wooden detail on the sides so that its easier to apply wood texture decals.
