Old 08-09-2002, 01:25 AM
microrcracing microrcracing is offline
batteries
The Epoch stock pack is a 3.6 volt 1/3 aaa(3 cells)
Our pack is 4.8 volts 1/3 aaa nimh (4cells)
Very fast Epoch!
Old 08-09-2002, 01:31 AM
gertman's Avatar
gertman gertman is offline
There is room to mount a 4th cell!!!! WOW
I can't believe the ESC didn't blow with the extra voltage
Are the cells you are using 250 mah NiMh cells?
Could you post a picture, please.
usagi's Avatar
usagi usagi is offline
These cars and other like them are that hard to find in your parts of the world? We can find them every where here.
Old 08-09-2002, 02:19 AM
gertman's Avatar
are mod motors availble for the Epoch's over in Japan?
Old 08-09-2002, 03:55 AM
usagi's Avatar
Yes, we can find them, amount other stuff.
Old 08-09-2002, 11:03 AM
tinyrc's Avatar
tinyrc tinyrc is offline
usagi, the Epoch only just came out over here, we're one of only 2-3 companies that sells them so far.
Old 08-09-2002, 11:05 AM
usagi's Avatar
oh I see......... gee they been out here for awhile.
Old 08-11-2002, 02:53 AM
Thumbs up
I am really not tight lipped as you said in other forum
Here is a link to the picture. It is availble for purchase. I have actually put more cells in a spec 1 before with out hurting the esc.
But, the spec one is not a slap in mod. It requires lots of work.
Photo of Spec 2 Battery
Please post info in other forum.
Old 08-11-2002, 05:15 AM
gertman's Avatar
You weren't kidding, it was TUFF to get back together! Yes, I had an extra cell from one of my friends Spec 1 which died I am going to post step-by-step directions with pics on another site and put a link here when I am done.
It is faster!!
Thanks for the idea
Old 08-11-2002, 11:18 AM
P.s.
Don't forget that if you assemble pack yourself that that run times may be shortened due to soldering process. The tiny 1/3 aaa batteries hate too much heat.
Old 08-11-2002, 11:42 AM
gertman's Avatar
AND
I am not such a great solder'er so I probably did over heat one of the cells!
It still works good for now. I haven't tried to re-charge it yet? Can you STILL use the standard Epoch charger?
Thanks again!!
Old 08-11-2002, 12:00 PM
tinyrc's Avatar
Good point - do you need to double-charge or anything? Could you use a peak charger with the Epoch connector? What amp rating if so?
Old 08-12-2002, 12:39 AM
gertman's Avatar
It took me almost as long as the actual mod , BUT pictures and a step by step guide is posted!!!!! HERE
ENJOY!
Old 08-12-2002, 01:02 AM
tinyrc's Avatar
Wow gertman, nice job!
Old 08-12-2002, 10:04 PM
Batteries
Gertman,
You forgot to mention that the Spec 2 batteries could be purchased already complete, spot welded and shrink wrapped at Spec 2 batteries
They fit better and run longer than homemade packs. A little credit for the mod would be nice too. Instead of some guy in some forum.
Need Answers! truckian XMODS 2 01-10-2005 08:21 PM
Pitwork Skyline reveiw Adam Digi Q 5 02-10-2003 10:56 PM
Compatability Answers Between Zip Zaps and Bits kwikbb ZipZaps 1 12-09-2002 05:03 PM
relay Technology in other cars bigbamboo Auldey (All) 8 12-01-2002 06:40 AM
