11-23-2002, 11:44 PM
Bus Driver!
First off. I must be mad.
If you had a small enough camera would be a outstanding thing to go down gopher holes hunting ghopher's or rabbit's!  Or through duck work!
Could the first to get one answer the queston that had driven us all mad. How in the heck does it turn! Tnks!
11-23-2002, 11:51 PM
smoove operator
Theres a thread by irc that gives a description somewhere in the forum... basically it uses a similar drive system to the digi's, using one motor with some kind of transfer axel to slow either the left or right wheel during turning.
11-24-2002, 12:02 AM
I own you
It slows one side down. If your driving straight, the right side tires and left side tires are spinning at the same speed (hopefully). Say you wanna turn right, then the right side tires slows down alot and sends more power to the left side causing it to rotate and its the same way around. Its like a tank without the treads.
1/8 X-Terminator
1/8 Thunder Quake
1/10 Nitro Blizzard
1/10 E.Stampece
1/10 E-maxx
1/10 Evader BX
1/12 Nitro Legends
1/12 Digger 2
11-24-2002, 01:25 AM
Bus Driver!
Cool!
12-03-2002, 04:22 PM
here's mine!
i just bought a Wild Char-G the other day.. its sweet!!! here's a pic comparing the size with the AE86
12-04-2002, 08:14 AM
smoove operator
Re: here's mine!
Hey sketch, nice "PowerMate" in the bkgrnd... I wanted to get the limited black ver. myself.
12-04-2002, 04:23 PM
Moderator - Modifier
So can you confirm us in detail how the innards look?
12-05-2002, 11:24 AM
here is the inside
inside of my beast
12-07-2002, 02:28 AM
Ahh I see both motors. the box image alludes to possibly a third motor oriented down the middle the way Bit racer batteries are positioned. Can you confirm that? So are they 4wd and how do they steer? Do they have suspension? thanks for the pics.
12-07-2002, 05:05 AM
no 4wd
no it has 2wd and it steers like a tank.
no it only has two motors i checked inside.
ok how it steers.
it goes with the one back mototr but then when u want to steer, a magnet pushes a gear to one side of the car then one wheel goes faster than the other one that makes a angle turning movement but becuase the other wheel is still moving but slower it turns will driving.
i will try to get some more pics but of the actuall inside of the car.
i wouldnt recommend this as it takes very steady hands to put back together after u take it apart.
and the gears keep on falling out.
p.s it has really kool suspension in the front i will attach a quick pic i made of the sus.
12-07-2002, 05:24 AM
re: sus
[i]
p.s it has really kool suspension in the front i will attach a quick pic i made of the sus. [/b]
12-07-2002, 12:39 PM
Thanks for the info! I can see some great mods coming out ofthis one!
12-07-2002, 06:08 PM
what motors do the monster trucks come with?????
12-08-2002, 04:08 AM
motors
well i think the one that drives the beast is a 2.2 but i changed it with my 3.0 it is still abit slow and it screams.
and the one that moves the gimmick i think is a 1.0 or 1.6 but it is actually connected with wires.
12-19-2002, 08:53 PM
can u put regular bit bodies on the monsters??????
ahhh hippos!!!!! run for your lives!!!!!!!!!!!
