Old 05-08-2004, 02:20 PM
eLeMeNt_sK8er04's Avatar
eLeMeNt_sK8er04 eLeMeNt_sK8er04 is offline
i think ill die early ..
Send a message via Yahoo to eLeMeNt_sK8er04
No repy to your Post. just wanted to tell you to check out MY thread please.
Old 10-05-2004, 02:24 PM
moebrown20's Avatar
moebrown20 moebrown20 is offline
Send a message via Yahoo to moebrown20
I have found a site that sells lithium-ion.
http://www.slavin4u.com/lithium.html
They are much cheaper than $19 bucks.
Old 10-07-2004, 03:13 PM
mod_o_matic mod_o_matic is offline
me sent a emial 2
So is there any update? Like has the circut or charge been made!? GIVE ME A UPDATE!!!
Old 10-21-2004, 12:50 PM
rssjib rssjib is offline
Too many XMODS
The Li-Ions at AtomicMods are $9.95, not $19. Get the info straight please. And you can get them with solder tabs. If you join their forum and have at least 10 posts, you get a discount, and the Li-Ions are $8.95 each.
I have purchased some of them and they are kick-butt.
RSSJIB
(2) Yellow Skyline GT-R: AWD, AtomicMods 180S motor, Li-Ion, CF driveshaft, suspension, bearings
(2) Black Skyline GT-R: AWD, Stage2 motor, Li-Ion, suspension, bearings
'04 Mustang: AWD, AtomicMods SS130 motor, Li-Ion, suspension, bearings
C5 Corvette: AtomicMods SS130 motor, Li-Ion, suspension, bearings
C5 Corvette: stocker
(3) STi WRX: AWD, CF chassis, AtomicMods SS130, bearings, body kit, Li-Ions coming
Black RSX: AWD, Stage2 motor, suspension, bearings
Silver RSX: stocker
Red Supra: AWD, Stage2 motor, suspension, bearings
Silver Supra: body kit, Li-Ions soon
(2) 350Z: body kit, Li-Ions soon
NSX: body kit, Li-Ions soon
'65 Mustang: body kit, Li-Ions soon
_________________________
"rehab is for quitters"
Old 10-21-2004, 01:15 PM
jon.jon's Avatar
jon.jon jon.jon is offline
This topic is almost a year old they might have been $19 ea back then.
Old 11-16-2004, 09:26 PM
dIsEaSe dIsEaSe is offline
I am going to buy 2 cells from Rob, and his little charging unit with the LEDs.
I have a few chargers around here from various things (cd players, cell phones, etc)
All 12V, and 300mAh, 350mAh, 500mAh.
What is the recommended mAh output for these cells?
Old 11-17-2004, 08:29 AM
moebrown20's Avatar
Rob uses the 500(i think), so you should be fine.
Old 11-17-2004, 05:29 PM
Perfect, thank you.
Old 11-17-2004, 11:50 PM
My next question.
Is 18 gauge wire needed? Can it be any less?
I have quite a bit of a certain wire, but I'm not sure what gauge it is. Is there a way to find out?
(is 18 gauge the wire used to go to electrical outlets and switches?)
Old 11-18-2004, 06:28 AM
moebrown20's Avatar
My next question.
18 gauge is the best wire to use(too small it tends to heat up, too larger, it becomes a weight factor). Electrical wire is 16g and larger(16 is used with small light fixtures, you will mostly see 14 and 12 in your house) for the home. RS has a plastic gauge finder (most likely on their site) to find out what size it is.
Old 11-18-2004, 11:31 AM
gnubee gnubee is offline
lithium ion and lithium polymer rechargeables are dangerous. burn your house down dangerous. water speeding the reaction dangerous. a jet of white hot plasma shooting out of them dangerous.
that said i use lipo whenever i can. the mah, v, wt, and sz are unsurpassed.
if you hack apart a celphone charger to charge lithium with be careful to match charger output ma with the battery size. a 250 mah lithium can only be charged at 250 mah or less. or it will explode and burn uncontrollably. same thing can happen with a fully charged lithium battery if accidentally shorted. or charged after discharging below 3v per cell.
this is not stuff for kids to play with. even smart kids that are patient and knowledgeable.
please have your parents help you if you are under 16.
and charge in a ceramic pot outside your house.
Old 11-18-2004, 11:35 AM
moebrown20's Avatar
I know.
I there is a thread on that already.
http://www.tinyrc.com/forums/showthr...ht=lithium+ion
Old 11-18-2004, 12:36 PM
jon.jon's Avatar
This is wired up by 14ga and I notice a big difference in acceleration its like instant boost now.
Old 11-18-2004, 12:38 PM
You guys have me all scared now :P
But if I buy 2 cells, and the little charging unit with LED's from Rob, use my own 18 gauge wiring, and a charger rated the same as the one on his site, it should be fine ?
moebrown20's Avatar
Sweet Jon.Jon.
What kind of motor is that?
Lithium Ion installation bengali548 XMODS Parts and Hop-Ups 18 08-01-2006 12:25 PM
Overview On Lithium Ion Batteries moebrown20 XMODS Mods and Projects 19 05-02-2005 08:00 PM
lithium ion get sideways XMODS Mods and Projects 3 01-17-2005 12:07 PM
li-ion ac adapter for li ion kit ?!?!? help chooch XMODS Mods and Projects 7 12-17-2004 08:38 PM
Question for ION and all: SP Frequency 40abc compatibility bdnunchaku Bit Char-G / MicroSizers 12 05-21-2004 11:43 AM
