Old 10-30-2003, 06:25 PM
Bad Company's Avatar
Originally posted by Nii
Thats mad sick and all but i wa wondering where or not u had o drill hole into the bottom to the the Plate to stay?
Just use the 2 screws to either side of the on/off switch. Back them out and put them thru your plate and back into the original holes in the chassis.
Old 10-30-2003, 06:39 PM
Nii Nii is offline
Oh thats hot. Thanks for the info.
Oh ya. I also heard that u have to drill holes to pu the spoiler on. Is that true?
And one more thing. I heard that the cooler u keep your engine, the higher performance it has. Does this mean i could go out in the winter when its really cold out and not snowing, and acheive greatly improved perforance, or will i just end up breaking the electronics somehow?
Old 10-30-2003, 10:53 PM
lilcricket lilcricket is offline
Send a message via AIM to lilcricket
well for the most part, moving parts will wear and break...electronics...use doesn't really kill electronics....heat does...so the cooler you run it, the longer it'll last basically....same goes for like computer processors and such....the hotter it gets, the more chance it has to fail, but it you run it very cool, then you "can acheive" better performance, but with certain modifications.
Old 10-31-2003, 01:40 PM
Nii Nii is offline
Aight thanks
Old 11-24-2003, 11:25 AM
KnotHole's Avatar
KnotHole KnotHole is offline
JesUSAves
Thumbs up Coke Bottle Skidplate...
Lilcricket...Just wan'ted to let you know that your skidplate idea is a "GREAT" idea. Not only will it work but it being clear makes it even better. Keep up the good work.
Old 11-25-2003, 11:43 AM
aperson's Avatar
aperson aperson is offline
I'm not a pyro, really.
i did this a while ago but when i cut it i cut it vertically so it was bent down a little bit and i didnt have to roll it up and leave it overnight. i also mounted it with the screws on the front tab and the bottom screws used to hold the rear bottom plate on.
NEVER UNDERESTIMATE THE POWER
Old 11-25-2003, 01:20 PM
SKYHIGH SKYHIGH is offline
yeah I was wondering has anyone made a wrap around roll cage yet? my skykline is tow up
Old 11-27-2003, 01:57 PM
aperson's Avatar
what do you mean wrap around roll cage? an actual bar roll cage or a piece of plastic that's wrapped around the chassis?
Old 01-05-2004, 01:30 PM
nrsjs's Avatar
nrsjs nrsjs is offline
Ok, as far as finding flat plastic goes, I don't think it should be a problem for too many of you... you all mod, right? On just about any XMOD mod (motor upgrades, awd, and toolkit are the ones I know do) there is a plastic cover that is about the same type of plastic as a soda bottle. That's what I used...
Old 01-13-2004, 08:04 PM
xmodsman's Avatar
xmodsman xmodsman is offline
Send a message via AIM to xmodsman
Thanks, I will have to try that
blue RSX
wild silver body kit
stage 2 drift motor
5th cell mod
soft springs front
hard back
3.5 steering
custom plastic skidplate
white rims
metal lugnuts
mini-z tires
and custom painted chasis
Old 01-14-2004, 05:22 PM
raytard
im too lazy to do that, i just took sum extra stickers and put them over the bulgy parts, works really well, i had it so that there was 1 bomex sticker on a slant on each knob, lik \___ over the knob... much quicker and easier
Old 01-14-2004, 08:32 PM
dietryin's Avatar
dietryin dietryin is offline
title? i dont have one!
Send a message via AIM to dietryin
Lightbulb my tut on the squidplate
well i did this a loooong time ago...
Heres my instructions:
Parts/Items needed:
2 liter bottle of soda plastic ( what i used )
Rasor blade/exacto knife/scissors
marker
Brain
X-Mod of course
Instructions:
1.cut out a rectangle out of the bottle a bit bigger than ur car
2.roll it the opposit way and put a ruberband on it
3.let sit over night
--Next Day--
1.Take rubberband off
2.take body off of car
3.set plastic on underside of car
4.trace wear u want the skidplate to be with marker
5.mark out holes for screws,on/off switch and rear lock
6.cut out with form of knife/scissor
7.unscrew the screws u marked with marker
8.poke holes in plastic for where ur screws u took out were
9.screw in screws
10.Tear It Up Where ever!
Jay Jay
P.S. U people gotta remember.. im only 13 lol
just say no to big sigs
heh.. stolen from viperdout^
Old 02-21-2004, 08:19 AM
dietryin's Avatar
anytime..
Old 02-21-2004, 08:40 AM
Racer9's Avatar
Racer9 Racer9 is offline
Tiny RC Pro
I have those batteries!
Skid Plate Bad Company XMODS 39 11-23-2006 08:39 PM
alloy awd steering plate? incendiaintus XMODS Parts and Hop-Ups 2 08-29-2005 01:44 AM
front skid plate GrandRC ZipZaps Mods and Projects 2 03-30-2005 12:30 PM
"Rally" Skid plate Railside270 XMODS 10 01-03-2004 12:07 AM
clear skid plate scrody XMODS Gallery 2 10-30-2003 08:01 PM
