04-12-2003, 11:52 PM
Proud to be Pinoy :)
hehehe
04-13-2003, 12:11 PM
Overworked
Arch,
Explain a little about your axles.
Are you going to use the axle that the gear is on? If so, why press it off? If not, what do you mean by 'stock' axle?
I ask because I am not sure which axle you have the wobbly wheel on.
The answer to fix the wobbly wheel can be ultra simple, like glue (and hope it stays centered). Or it could be more difficult like using a larger diameter axle which might involve dilling out the gear to match.
I guess I never really asked you what your drivetrain would be. Can you eleaborate?
-Todd
_______________
I just like to build.
Micro RC for way over a decade
04-13-2003, 12:43 PM
TinyRC & Mini-zRacer Fan
sorry, the faller axel is slightly to short  so i have to pop it off the faller axel, which i haven't been able to do so far, and slide it n the stock roco axel. that is the axel that one of the wheels has become wobbly.
i'm not oppossed to using a new, slightly larger diameter axel only i can't find steel rods that small, not to mention almost impossible to find metric stock anywhere.
i had an idea to use a new slightly larger diameter axel with threaded ends so i could screw on/off the wheels. but i can't find the materials and don't have the tools. any chance you have the ability to do this?
04-13-2003, 02:10 PM
Overworked
I cant thread rods smaller than 1-72. I can tap holes smaller though.
I think the glue is the best bet. In fact, use high stregnth Loctite that you can find at any auto parts store. It is strong enough for TTTT but is not perminent like CA. Shake the tube well and just use a drop. I think the wheel wobble is a minor thing and it can be put off until you are almost done.
To press the gear off the shaft, try to hold the axle vertically on the workbench, then use pliers above the gear and push down. do not pinch the shaft with the pliers, just close them enough that they make good contact with the face of the gear and try to push down evenly. It should come off. Put some steady force behind it.
You could also try tapping with a small hammer. Use the tubing method like I told you to do with a vice except hold the shaft in the longer tubing vertically. Then instead of using the vice to press, use the hammer. Put a peice of brass or a penny in top of the shaft and hit the penny so the shaft wont mushroom as you tap with the hammer. I vise woulkd definitly come in handy here, just as a third hand.
I know the Faller axle is not long enough, but it is the same diameter as the Roco shaft?
-Todd
_______________
04-13-2003, 09:08 PM
thanks overlander, i'll try that.
yes, the faller axel appears to be the same diameter as the roco axel.
i'll have to stop by the hardware store one night this week to pick up the high stregnth Loctite. i need it anyway for all the screws/nuts/washers. the vibrate loose constantly.
i made some progress on my project on the elctronics, i've posted in my thread in the gallery section. i also posted another question you might be able to help me with in the tttt elec.s thread.
off topic- one of these days, i'd really like to get your review of the new acad software!
04-16-2003, 10:43 PM
now all u guys need is a ball diff for them
In my garage, X-mods and Mini-Z are not competitors. Both get stuck just as easy, pull the same amount of weight and are equal on fuel. Why be picky?!
04-17-2003, 09:41 AM
I know its not a TTTT but it has inspired me to bilut a HO scale tank A.K.A TTTT.
04-17-2003, 09:43 AM
OOps forgot the phot.
04-17-2003, 10:37 AM
i love tanks myself, the 1/16? are very cool, way to expensive.
btw- better place for tank building
04-25-2003, 01:45 PM
off topic!!!
this is off topic, but i've been working on some other projects as well, check this one out!
04-25-2003, 02:02 PM
Overworked
Off Topic!!
Hey Arch, that was a cool slide show/tutorial! You are a soldering maniac!
Be sure to go here http://pub24.ezboard.com/frcmtnet449...icID=106.topic and vote for BulletProof.
-Todd
_______________
04-25-2003, 08:18 PM
switcher
hey im new to this flavor of mini rc. i just read the slide show tutorial (awsome job arch) and all 25 pages of this thread all i can say is wow.
what if the hokey pokey really is what its all about?
04-25-2003, 08:31 PM
thanks rallger, there is some greatwork in here  anychance you'll be adding to it?
04-25-2003, 10:21 PM
Overworked
Wow Rallger! All 25 pages!!
I hope you feel inspired to build one of your own. You will get as much help as you need from the guys on this thread.
Forgive my blatent campaining in my previous post..
_______________
04-25-2003, 10:34 PM
overlander is being modest  he helps alot himself. even convinced me i could do it
