Old 03-30-2003, 07:17 PM
Swavey's Avatar
Swavey Swavey is offline
Got Avatar?
Now all we need is a Zip Zap owner or an extended bit owner willing to smack some huge tires on there and giver a go!
would definatly need a custom body, or custom mounts for the bit racer bodies...
This would enable a bit to go anywhere! heh would be fun i think.....
*imagines flying into a wall at top speed, bouncing up and around, tires still spinning, then taking off the second it touches the ground*
*** AmC Certified ***
Old 03-30-2003, 07:38 PM
nrmcj's Avatar
nrmcj nrmcj is offline
Rice Me
i smell a tiny Tyco Rebound on this project here....
swavey, i think it'd work great.. just like the big version.. but the only problem is, do you have the torque to flip the car over at will? you know what im saying rite...?
im thinkin whoever wants to do this is going to need at least 2 cells, and a clone PCB....
it will work if you try hard enuf ^_^
Old 03-30-2003, 08:03 PM
Zephyranthes's Avatar
Blitzer Sonic
That's what its called! The Rebound. Would the car be able to push these big tires and would it be able to fit on the charging pad? How high do you think it could handle. I want to drive it off my balcony, or maybe attach a parachute and put a humvee body on it. Paratrooper bit.
Old 03-30-2003, 08:11 PM
Swavey's Avatar
Got Avatar?
I actually have a Tyco car very similar to the robound... heh not sure if it is one or not... the tires are filled with air and stuff so it used to really bounce....
That was my insperation :P
I think:
- Bit PCB would do
- Dual Cell IS needed
- Extended Bit, or ZipZap chassis would be best. so you can acomodate the dual yet maintain the low profile.
- Big tires to get both sides off the gound, with reasonable clearence.
Old 03-31-2003, 05:21 AM
strider_mt2k
I was running my "Another Monster Wheelset around on my newly dual-celld car, and my conclusion is that the first time you smack the wall with one of these cars it will break something!
I am shelving my even larger wheelset for the moment, mostly because I want to make another Lego Wheelset with the Zip Zap wheels I have.
Another reason is that huge heavy wheels are simply overtaxing the drive and steering systems and while I may try a tri-cell soon to see how it is, doing a brute-force approach and dumping more power into the system is not the best solution.
It's the weight of the wheels that killing it from what I can see.
A big huge set of foam wheels would be perfect. Heck, use closed-cell foam, and the stupid thing might be a puddle-jumper too!
Old 04-03-2003, 08:48 AM
T_T_52
I making a MPH body fit so I'm going to
do some moding an the hood on the back. I already got a 1" in diamiter rear wheel set just need more power since a 2.6 it too weak. Oh and the gearing on my wheels is ZZ green.
Old 04-03-2003, 08:50 AM
T_T_52
The Germans did it again. www.bitmod.tk
Old 04-03-2003, 09:56 AM
strider_mt2k
OOoooh! Good idea!
Looks like a moon rover kinda.
Flipping your modded Auldey Distress Auldey (All) 9 09-23-2003 08:36 PM
How can I make my Zip stop flipping? Eli ZipZaps 32 06-24-2003 03:06 PM
re: tired of flipping on high speed turns? jedclampit Bit Char-G Mods and Projects 18 05-21-2003 04:53 PM
Flipping the pcb over Zephyranthes Bit Char-G / MicroSizers 2 03-04-2003 10:47 PM
Stopping it from Flipping joeNuggetz ZipZaps 4 11-16-2002 11:21 PM
